Question about Cuisinart CPT-160 Metal Classic 2-Slice Toaster
My cuisinart cpt 160 toaster won't start
The lever will not hold in the down position to start the toasting cycle
    President:
  • 1,185 Answers
Do any of the lights come on ?
If not then have you checked the plug top fuse
If the lights come on and then when you press the lever down it does not latch a solenoid has gone open circuit
Good toasters can be fixed
Cheap ones go in the trash bin
Posted on May 29, 2009
The thing you push down to activate toasting will not stay down
Check to insure the surge protector has not popped out. Reset and try again. Make sure its plugged in or it will not stay down.
Feb 01, 2016 | Cuisinart CPT-160 Metal Classic 2-Slice...
How do i Opened my cuisinart toaster cpt180
The Instruction Booklet for the Cuisinart CPT-180C Classic Metal 4-Slice Toaster can be found at the following link:
http://www.cuisinart.ca/pdf/ibs/en/CPT-180C_en.pdf
Not sure what you are trying to open. There is a slide out catch tray for cleaning crumbs. There is no information in the booklet that suggests a need or a way to open the toaster.
Perhpas reviewing the booklet will answer your question.
Jun 28, 2012 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
The left side slots will not lock in the down position to cook the toast what can I do?
There may be a broken wire inside on that side of the toaster as if all power were out, neither would lock in the down position...
Best Regards
Ck
Jan 05, 2011 | Cuisinart CPT-140 Cool Touch 4-Slice...
Lever to start the toaster will not engage consistently and makes a horrible sounding noise. After several tries with different pressure, it will engage. The question is "how long before it will no...
mcdevito75 here, If the lever mechanism is worn it could give out at anytime, the sound you hear is like gears grinding, make sure the setting for Darker / Lighter toast is not set too low, set it for Darker toast and then see if it"s better.
Jun 22, 2010 | Cuisinart CPT-60 Custom Control Total...
I can't figure out how it goes back together. The toaster lever wasn't working, so my wife took out the crumb tray and turned the toster upside down thing something was jammed. A long metal rod and long...
That long rod and spring sound like the rod that the opperating lever rides on, kind of a guide, the spring is what pops it up when the toast is done .. should be sitting verticle in a groove or hole in the opperating lever.
Jun 02, 2010 | Cuisinart CPT-70 Classic Style 2-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
My toaster doesn't stay in the down (toast) position unless I hold it down
I solved this problem on my Cuisinart CPT-90 Classic Style Toaster twice for two different problems. Of course: make sure it's UNPLUGGED while working on it and WATCH IT several times when testing so you can unplug it first and then extinguish it if it catches on fire.
1st time: There is a small solenoid mounted in the center of the circuit board. When the pop up mechanism is pressed down the circuit energizes and the the solenoid magnetically locks a plastic clip that holds the spring loaded pop up mechanism down until it's done toasting. The plastic mounts for the circuit board broke or weakened until the whole circuit board would tilt up and the solenoid clip would slip under the spring tension. I used a plastic tie-wrap to hold the circuit board firmly in place and that worked to this day.
2nd time : The four copper reed tabs can be miss aligned. If they
do not make contact, the circuit will not energize the solenoid.
The reason they warped was that, over time, the contacts build up carbon and have more resistance. Resistance equals heat. The
plastic base of the copper reed switch melted and misaligned the reeds. The second time I cleaned the reeds and bent them back into position, The third time the the plastic was to badly burned to be reliable. If I had cleaned the contacts once a year, it probably would still work now. I haven't found a place to buy a replacement reed switch so my toaster is toast. If anyone knows where to order them, I'd like to know. If the white plastic base of the reed switch is not melted, then they can be cleaned and aligned.
Note: When aligning the copper contacts, don't just hold down the pop up mechanism. The pop up mechanism will push lower than the position for toasting. Push it down and then hold the solenoid clip instead. Then the two center reeds will be at the correct spread.
Aug 14, 2006 | Cuisinart CPT-90 Classic Style 4-Slice...
Cuisinart CPT-160 Metal Classic 2-Slice Toaster Logo
790 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
