My emachine is very slow and often sticks
My emachine #T5088 is extremely slow in booting up and often stick on
one item.
  • William Miller May 29, 2009
    How do I increase RAM memory
    President:
  • 987 Answers
Try to increase the RAM memory to speed up..
Posted on May 29, 2009
  • Sibananda May 29, 2009
    Purchase a DDR2 RAM and install on the motherboard..
    Your System support maximum of 2GB
    Problem Solver:
  • 15 Answers
Yeah you most likely would see some speed increase with some extra ram. i would add the max your computer can take to be honest with you. If you want to know some info about it, go here
http://www.crucial.com/
there is a scan tool for Ram that will help out tons.
hope it helps
Posted on Jun 19, 2009
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
I AM TROUBLESHOOTING AN EMACHINE MODEL W3410 AMD ATHLON THAT JUST CONTINUES A LONG REPEATING BEEP AT BOOT AND AM NOT RECIEVING SIGNAL TO MONITOR. IS IT MEMORY OR VIDEO . CAN'T GET A CLEAR TOPIC FOR THE...
Almost always indicative of a RAM memory problem. Troubleshoot by removing 1 stick of memory and rebooting. Switch sticks to determine if either stick of memory is bad or a bad bank on the motherboard.
Nov 23, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
For 5 years i had 1 gb memory single stick in my eMachines W3502 desktop PC, and it was running good, untill i installed windows 7 ultimate 64bit, it`s still runing good, but sometimes it gets slow because...
Do you get any error beeps when you turn on your computer? Check this list here: http://www.5starsupport.com/info/beep_codes.htm
Also, there are three different types of RAM: DDR1, DDR2 and DDR3. I have never come across a computer that will run two different types simultaneously, if your motherboard supports both DDR2 and DDR3 (The pins and key are different, so they won't fit in a non supported slot)
If both sticks of RAM are exactly the same, try running it in dual channel mode, by inserting the RAM sticks in the same coloured slots on motherboard, providing your motherboard supports this
Apr 16, 2010 | E-Machines eMachines Desktop PC
Which slot to place one memory stick in to boot using only one stick of ram? Emachines T2341
slot one if it does not boot up then use the next slot slot two make sure you have the right memory for the machine
May 27, 2009 | E-Machines eMachines Desktop PC
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Feb 02, 2009 | Dell Inspiron XPS M140 Notebook
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
