Question about ASUS Eee PC 901 XP Notebook
Frozen eee pc 901
Eee pc 901 its powered up but it seems to be frozen tried to reset it but still nothing, tried to boot with a copy of the disc on my stick memeory but still nothing
  • gusmacd2003 May 29, 2009
    i mean, that the power light etc. are on, you can hear it running when you put your ear to it, but the screen stays black, the wireless light is on and i have tried to turn this off but nothing happens, tried the reset button still nothing
  • USBanker01 May 11, 2010
    When you say frozen, what do you mean? Does the os load up? Or does it just stay black and make a beeping sound?
       `Nbryson
    Problem Solver:
  • 21 Answers
I would guarantee 98% that its your harddrive. I had a similar problem w/ one of my older computers. I installed a new harddrive and that fixed the problem.. Stay away from seagate hds, they are junk.
`Nbryson
Posted on May 29, 2009
In ASUS Eee pc 901 i had ubunt and tried to install win xp h.ed sp1 included from usb,win copied fails and restart the comp and it tells NTLDR is missing press any key to restart tried whid and whidout...
XP has a problem installing directly from (non cd) usb devices by default. try it with a usb external cdrom and an actual windows cd (known to work) or reinstall ubunt and run windows as a virtual machine or if you are really into computers and really really need to install xp from usb try the link below. (good luck)
http://www.ngine.de/article/id/8
Aug 24, 2010 | ASUS Eee PC 900 Notebook
Asus eee 901 will not start
Try this - open the laptop up and on the motherboard there should be a small round flat battery (bios/cmos) take this out and leave it out for atleast 20 minutes then put it back in and startup the laptop. Hope it helps, leave me a comment to let me know!
Aug 09, 2009 | ASUS Eee PC 900 PC Notebook
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
How do i reset a eee pc 901
To reset my 901 XP, I remove the battery as shown on page 3-3 of the instruction manual.
The reset button can now be accessed: it is a small shiny metal
plate, about 3mm by 15 mm located on the left of the battery compartment (closest to the LAN port).
Press the metal plate once with a ballpoint.
Jul 11, 2009 | ASUS Eee PC 901 XP Notebook
Eee PC 1000H/XP - my wireless connection stopped functioning
1) Try to check your connections. Follow the guide from Microsoft, here: http://support.microsoft.com/kb/314067
2) You could try reseting your TCP/IP stack. Try this:
  1. To open a command prompt, click Start and then click Run. Copy and paste (or type) the following command in the Open box and then press ENTER: cmd
  2. At the command prompt, copy and paste (or type) the following command and then press ENTER: netsh int ip reset c:\resetlog.txtNote If you do not want to specify a directory path for the log file, use the following command: netsh int ip reset resetlog.txt
When you run the reset command, it rewrites two registry keys that are used by TCP/IP. This has the same result as removing and reinstalling the protocol. The reset command rewrites the following two registry keys: SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
Mar 17, 2009 | ASUS Eee PC 1000H Laptop
I have a problem with asus eee 901. I've just bought it. It had linux, but it was changed into windows xp. Since it had been fully charged only once I was using it on battery and setting it up with new...
Remove the battery for a couple of minutes while the unit is not plugged into the a/c adaptor. Reinstall the battery, plug the unit into the a/c adaptor, and see if it will boot up.
Mar 14, 2009 | ASUS Eee PC 901 20G Notebook
Frozen Laptop
Can you use the keyboard? If you can then the mouse software is damaged. If you cannot use the keyboard then boot to safe mode. If safe mode is frozen then the problem is hardware.
Jan 25, 2009 | ASUS Eee 4G Notebook
ASUS Eee PC 901 XP Notebook Logo
686 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
