Question about Canon ImageRUNNER 330s Copier
On copier sow display bord "Swith main power off and on E001
When I switch on copier then sow display bord "Swith main power off and on E001"
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
Posted on Nov 12, 2009
  • Canon Expert
  • 1,326 Answers
That error code means that there is something wrong with the fixing unit... Try to get into service mode by pressing: The "add. Fun." "*" then the numbers "2" & "8" at the same time then press the "Add. Funt" botton again... The display should change. Press the Funcation on the top of the display, then press the "CLR", then "ERR" then the "OK" in the bottom coner of the display.. Turn the MAin power switch OFF on the right side of the copier, then backk ON. If the problem is not resolved you most likely have more problems with the fixing unit.. Good Luck..
Posted on May 31, 2009
  • mani
    mani Apr 19, 2014
    my control pannel is no reactions
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Canon MF4412 turn the main power on E000-0000
Apr 18, 2012 | Office Equipment & Supplies
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
E00001-002 Error cod?
Thanks for using Fixya.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Canon GP335 - error E001
E001 is a no heat error.Open and close the front door.If that does not work you will probably have to call a copier technician.Good Luck
Mar 27, 2009 | Canon imageRUNNER 210S Copier
When I switch on copier then sow display bord "Swith main power off and of E051" Please solution... sambhu82@yahoo.com
This error code due to your machine gear had broken
this gear can change by only technician
because it in very critical area
if you open full machine then you can do
for change that gear you have to open machine from its manual feed stack bypass door.
firstly remove upper body cover
then open from front cover
then open front body cover
remove drum segment
remove toner segment
then remove pick up segment
then remove upper segment of pick up that was very critical
if break something or fit loose something your machine will be
not work
under that segment you will see one toothy plastic plate which moves with one small gear, that gear you have to change.
That its
Mar 20, 2009 | Canon ImageRUNNER 330s Copier
Power not on
sorry to say you have blown the main breaker on the main switch or your power cord is bad but on the off side check the power board for a bad cap.
Oct 20, 2007 | Office Equipment & Supplies
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Aug 23, 2007 | Toshiba e-Studio 350 Copier
260 people viewed this question
old marine
old marine
