TUB WON'T MOVE , EVEN BY HAND
THE TUB ON MY FRIGIDAIRE FRONT LOAD WASHER WON'T MOVE ,EVEN BY HAND
    President:
  • 1,185 Answers
Drum Bearing or Drive motor have seized
If the drum wont turn by hand you need to take the back off , unship the drive belt and try again
If the drum turns it is the motor that has gone wrong.
If the drum will not trun look at the bottom of the drum backplate , is there rusty watermarks
If there it the centre seal has given up and let water into the bearings, as the water contains soap it washes the grease out and the bearings stick.
Sometime if you give the drum pulley a really hard pull in one direction the bearings will come free
Even then it is a short term measure as they will seize up again by the next wash
Posted on May 29, 2009
  • 332 Answers
TAKE THE BACK COVER OFF, EITHER THE MOTOR IS SEIZED UP OR THERE ARE SOME CLOTHES STUCK BEHIND THE DRUM
My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum.
Welcome to FixYa.
Based on your description "My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum"
my first suspicion would be a worn tub bearing, unfortunately all too common with those Frigidaire.
The tub bearing is likely worn, or the inner tub has broken apart.
You can check this by way of opening the door and grabbing the inner basket rim and moving up and down to feel for play...there should be zero play or zero tolerance in this bearing.
Second, since you`ve removed the back panel, grab the large pulley and try and move it back and forth or spin it with the belt off to listen for a grinding noise.
If it is indeed worn it will require practically the complete tub assembly ( rear wall with bearing and inner basket )...that is the least expensive and easiest fix at around $400 for the entire assembly.
example...
You can opt to change just the rear wall and bearing with the basket in separate pieces, but it comes in around $370 and still leaves you with pulling the old one apart to re-use the front shell.
Either way this is a fairly involved repair and even for an experienced tech like myself can take 60 - 90mins.
Let me know what you find and I'll do what I can to assist you.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Sep 29, 2010 | Frigidaire FWT449
Washer drum made a ratteling noise when on a spin cycle and looks like it fell off the mount. Does not spin freely when you try move it with your hand.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire front loader washer makes a very loud knocking sound during the spin cycle before the final rinse. It intensifies the longer I allow it to spin. I have to shut it off before the cycle is...
from your description, it sounds like your washer is already broken - to check, open the door and reach your hand into the tub at the front top. push up. if the tub moves more than a fraction of an inch, the bearing and/or spider are toast. last time i checked, the PARTS were in the neighborhood of $450 and it's a BIG job! [read that: big labor bill]. this is a common problem with these machines and it's probably time to get a new washer. sorry!
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Spin cycle makes washer rattle too much
Open the door and then reach inside the washer and grab the front of the inner tub with your finger tips. Can you wiggle the inner tub inside the outer tub? If so, your spider shaft supporting the inner tub is cracked and needs replaced. It is quit a job for the average handyman. Most often the professionals mustr be brought in for this repair.
Let me know if I can help further,
Eric Campion
Mar 03, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Wash tub seems loose and is really loud
We just had that same problem last week. My husband took off the back of the washer and at the bottom you will see a shock absorber on each side. One side of ours was broken. $35.00 later for the parts (you get two in a package) and the tub is sturdy once again. Husband said it was fairly easy to do. Hope this helps!
Dec 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front Loading Washer - Load Banging During Spin Cycle
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
Dec 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Nov 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer FWT449GFS1 grinding sound
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Tub won't move
could be motor, control board, motor controler
Apr 10, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
327 people viewed this question
Top Washing Machines Experts
