Question about Olympia Mastertype 3 Typewriter
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Correction tape isn't working. I have it installed properly, I believe, but it doesn't erase anything..any ideas?
    Genius:
  • 1,218 Answers
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
Posted on Aug 19, 2010
Manual erase darkens type
Either your correction tape is old or the correction tape is not lifting to the proper position.
May 14, 2014 | Xerox 6010 Memorywriter Electric...
The correction tape will not erase properly
If the tape is moving and showing marks of correction attempts you probably have old supplies or a non correctable ribbon. Install a fresh ribbon & L/O cassette NOT AN OLD ONE FROM THE BACK ROOM.
DickyO
Oct 20, 2011 | Lexmark Wheelwriter 1500 Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
I changed the correction tape on our IBM wheelwriter 3 and it doesn't seem to be lifting the error. Any advise? The correction tape is not old and I had already tried moving it a couple of inches but it...
You may have a very old correction tape or ribbon, a non correctable ribbon or it isn't properly installed
Go to LEXMARK.COM for a downloadable manual.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 3 Typewriter
I have an AX-22 and when I replaced the correction
You probably don't have the dull toward the paper.
DickyO
Mar 15, 2010 | Brother Office Equipment & Supplies
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
Changed correction tape but still won't work
either; 1. you have a non-correctable film ribbon, (it should say correctable film ribbon on the box or the ribbon itself) you can check by taking a piece of scotch tape, hold it next to the letter you want to erase, sticky side towards the paper, and hit the CORR key, CAREFULL YOUR FINGERS AREN'T IN THE WAY. if it corrects, the ribbons ok. 2. make sure the DULL side of the corr. tape is faced toward the paper
Dec 02, 2008 | Brother GX-6750 Typewriter
Correction tape for my Smith Corona PWP 4500 plus...
Is it making all the motions of a correction? If so you may have put the tape on wrong. The dull side must be towards the platen.
DickyO
May 15, 2008 | Smith Corona Wordsmith 100 Typewriter
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Olympia Mastertype 3 Typewriter Logo
445 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
