Question about Panasonic PT-51HX41 51" Rear Projection Television
TV turns on but with no picture or sound
Greetings, my PT-51HX41 Panasonic projection tv has decided to quit working on me. I can turn the tv on but there is not any picture or sound. The LED is front of the tv is red and nonflashing and the tv does not shut off unless I press the power button. I have tried the easy fixes (unplugging it for several hours, tried different outlets, etc) but to no avail. Any thoughts on the matter would be greatly appreciated.
  • 1 more comment
  • Joygasm May 29, 2009
    Also if it might help, I was getting wavy lines across the whole screen for about a month prior to TV death. The lines would go away with a gentle push on one of the corners of the tv so I figured it was a loose component.
  • Joygasm Jun 18, 2009
    Had a Sears technician come out and said the tv needed a new deflection board due to some bad voltage regulators. Even then there might be further damage. So now the tv is a giant decoration for the living room... I think I will leave it there so it can be jealous of my new lcd tv when I get one
  • Joygasm Jun 27, 2009
    So I picked up a Samsung 52" B630 lcd tv ... the old tv is clearly jealous
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Tv is making a loud screaching noise and no pic or
Ur high voltage flyback transformer it dead.
U need a new one.
Aug 20, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Tv turns off in 3 min with buzzing sound
CK next to FBT flyback transfomer your hori output transistor ther is a Blue capacitor 2K volts look to see if it is bad.
Jun 23, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt51 hx 41e
Recheck all of your solder connections recheck and make sure everthing is pluged or reconnected right then retry set.
Nov 29, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Tv is zooming in and out
Sounds like you need convergence IC's. Don't let them use GENERICS/KNOCK OFF'S!!!
Dec 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51 in. Rear Projection
check the micro chip on the system control board.it could be bad.
Apr 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Horizontal lines when I first turn on my Pansonic 51" PT-51HW41 Projection TV
It's probably failing capacitors, does it squeal while this is happening?
Jan 14, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
