Question about Homelite Garden
Problems with my HomeLite UT20760 bogs down, no power
I'm having problems with my HomeLite TrimLite UT20760 running with any power this season. It starts OK on choke with primer pumped 8 times, and will idle fairly smoothly with the choke full open (position 3).
When I pull the accelerator trigger it bogs down or dies unless I carefully rev it up with little pumps of the trigger. Running wide open with the trigger pulled all the way there is very little power and it doesn't come up to the full rpms it used to.
Takes 45 minutes to do what I used to do in 10 minutes. HELP!
  • Anonymous Mar 24, 2014
    Runs on run position but when I rev it up it bogs down then shuts off
  • 284 Answers
Try this
you need to locate your muffler and find screws that remove a screen behind a plate you can remove on the muffler or behind the muffler itself
This screen is a spark arrestor screen and needs to be cleaned and put back or some would say discard all together, but i didnt say that.
give it a look see
this may be your problem and maybe not?
if it was you will see a trmendous difference afterwards
Posted on May 31, 2009
    Problem Solver:
  • 11 Answers
Play with its red screw when full throtal
Posted on Jun 11, 2009
Homelite trimlite engine runs but head does not spin
Sounds like the inner flex shaft has broken, slacken the tube up at the engine and pull the tube and shaft assemly away, pull the inner shaft out and inspect
Apr 14, 2012 | Homelite Garden
I have a UT20760 25cc Homelite Trimlite and I would like proper instruction on how to start the engine. Instruction on engine say to press fuel bulb 8 times, but I am not at all sure what position the...
Pull the cord with the lever in position 1, when it tries to run, put it in position2 and pull the cord again. Once it starts running, wait 30 seconds and put it in position 3. Operate in position 3 and hit the stop button when you are done.
Mar 25, 2010 | Homelite Garden
Homelite trimlite weedeater ut2000413. runs but has no power. bogs down. how can i fix
fri-st check your compression should be no less than 76 pds. you can try changing your fuel, high octane only, oil mix no older than 6 mouths after opening. oil mix must be (stbulized). if this doen't work you may need a leak down test done for seal fail-er. check your muffler to make sure its not plugged. if all is good a carburetor over haul is needed. good luck
Oct 14, 2009 | Garden
Where do I get a replacement screw for the muffler. Homelite Trimlite Model UT20760.
you can take your trimlite in to your local hardware store and match the screw right there in the store or go on line to homelite dealer to order. hope was some help
Jul 11, 2009 | Garden
Garden Logo
819 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
