Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Printer error code: 0x000000aa......
After I connected to my network, and sent an article to print.. it won't. it says either access denied or error code: 0x000000aa.
  • 1 more comment
  • bellaque48 May 29, 2009
    no i don't. i tried clicking on properties,then on administrator and then to ports, then clicked raw, then when i clicked on the configure port tab, that's when i get the error message that says: "an error occurred during port configuration. operation could not be completed. error 0x000000aa".
  • bellaque48 May 30, 2009
    yes, i do have a symantec program
  • meteshadow May 11, 2010
    do you have symantec virus program or anything belong to symantec ?
  • 23 Answers
This error is because the resource is in use, you need to empty your print queue before you can change ports or settings
Posted on Feb 02, 2011
Hi. First you have to check "Use printer offline" for that particular printer then you have to stop the Print Spooler Service then start it again and only now you may configure the port configuration for that particular printer. After you do that uncheck "Use printer offline" and voila: it works. Good luck
Posted on Jan 29, 2010
  • 489 Answers
Remove it.
Posted on May 30, 2009
SOURCE:
How can i replace front bumper for chana benni
Hi Ybojang,
The error you mentioned is related to the Microsoft operating system.
Please find the below article for your reference
http://winwiki.org/port-configuration-error-0x000000aa/
Hope it will solve your issue.
BR
Ganesh
Nov 25, 2014 | Motorcycles
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
Tip
Network Connection Always Shows Access Denied
If you are always getting Access Denied errors when trying to connect to a XP computer,
and you know you have the correct user names and passwords on the computer,
the solution may be a simple registry edit.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlSet / Control / Lsa
  3. Change the value of a key called "restrictanonymous" to 0 instead of 1
  4. Don't change "restrictanonymoussam" value.
  5. Reboot
on Sep 20, 2010 | Computers & Internet
OKI c5400 error 0x000000aa port comfig
Hi Fixya
BR
Ganesh
Nov 21, 2014 | OKI C5400 Laser Printer
Tip
How resolve cannot "Connect to Network Printer" with Windows Vista
One of the more interesting errors in Windows Vista happens when you try to connect to a shared network printer. Most of the time you'll receive an "Access is Denied" error when trying to connect even though you can see the printer on the network and everything else is working properly.
Everything else on the network appears to work properly, shared files, internet access, etc. However, you just cannot access the ahared printer and print.
The solution is to add the printer as a local printer and then try printing. Follow the directions below to accomplish this.
1. Go into Control Panel 2. Underneath the Hardware and Sound category, click on Printer 3. Click on Add a printer from the top menu 4. Click on Add a Local Printer 5. Choose Create a New Port with type of port remaining Local Port, then click Next 6. In the Port Name box type the path to the printer you wish to connect to and Click Ok
Ex. \\mycomputer\myprinter
If the computer you wish to connect to is named Bob and the printer is called HP then the path would be \\Bob\HP
7. In the Install Printer Driver screen, select your printer from the list or choose Have Disk and find the location of the printer drivers on the computer then click Next and then click Finish. 8. You should now see the printer installed in the Printers window. 9. Right-click on the printer and click Properties 10. On the General tab, click Print Test Page to test the printer.
You should now be able to printer from Windows Vista to this networked printer without any problems.
on Jul 20, 2010 | Computers & Internet
When i get into face book error message pops up sayingpage cant be access
Does it say "page cannot be displayed?" Or does it say "Access Denied?" Or does it say "Restricted?"
Can you get to any other website other than facebook?
If access denied or restricted usually means the site is blocked via network security/firewall or you are trying to access a portion of the site that requires login credentials.
If you cannot get to any other website including facebook, you have a network connection issue.
Check cables, recycle the power on your internet connection (DSL modem or Cable Modem) and try restarting your PC see if this reestablishes your internet connection.
Dec 09, 2013 | Toshiba Satellite Computers & Internet
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Invalid command, line 01 code 400
Mornach 9825 printer is error "Invalid Command! Line 01 Code 400 ".How issue this error.
Apr 16, 2011 | Monarch Paxar 9855 Printer
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
32,183 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
