Question about Scotts Company Garden
Where to find replacement trigger assembly for a SpeedyGreen 3000
The handle to my SpeedyGreen 3000 broadcast speader is cracked, so the entire trigger assemble is virtually worthless. Where can I find a replacement?
5 Suggested Answers
  • 508 Answers
SOURCE: I have a Scotts Speedygreen 0740 with a broken
google it!!!
Posted on Jun 25, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
  • 25 Answers
SOURCE: how do i calibrate my speedygreen 2000 broadcast
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
Posted on Mar 04, 2011
The setting handle broke. Can it be replaced?
I am sorry to hear about the problem you are having with your SpeedyGreen spreader. Sometimes we do have replacement parts available. Please call Scotts at 800-543-8873 to check part availability.
Jul 07, 2011 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts EdgeGuard DLX I want to apply ferti;izer at a 6# per 100 sq ft rate. What number setting would this be
If the proudct you are planning to apply has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can use that recommendation in your Scotts EdgeGuard DLX. If they do not have a suggested spreader setting for the SpeedyGreen or SpeedyGreen 3000, then this question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further.
May 13, 2011 | Garden
What setting do I use for my scotts edgeguard DLX when using lesco professional starter fertilizer 18-24-12, item#016420
If the product you are planning to apply has a spreader setting for a Scotts SpeedyGreen, or specifially for the SpeedyGreen 3000; you can use that recommendation in your Scotts EdgeGuard DLX . If they do not have a suggested spreader setting for the SpeedyGreen or SpeedyGreen 3000, then this question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further.
May 12, 2011 | Scotts Company Scotts Pro Edgeguard...
Need to know the setting to put out Stagreen's crabex crabgrass preventer
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Feb 21, 2011 | Scotts Company Scotts Lawns Edgeguard...
How do i calibrate my speedygreen 2000 broadcast spreader
Jan 24, 2011 | Scotts Company Scotts& Accugreeen 2000...
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
Feb 15, 2010 | Scotts Company Scotts& Accugreeen 3000...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Garden Logo
60 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
