I have MITSUBISHI vs60707 with no picture but has sound i replaced Qa500 because it was shorted on leads also replaced q533 because it was completely blown apart also a couple of resistors next to it and a couple of caps now i get a picture but it has an hourglass effect from top to bottom it seems as though something in the horizontal circuit isnt working Qa502 checks good but could be bad. could this cause this problem or could it be the flyback.I get an error code 12 when i do the self diagnostic on the set
  • 19,396 Answers
Hi, That is quite difficult to understand without testing.
First you need to perform a coarse adjustment procedure. A Distorsion at the top and bottom of the raster may significate that you need to do geometry adjustment.
You can follow procedure on service manual.
If you performed the adjustment and the problem persists, then he hourglass top and bottom is effectively horizontal deflection problem.
Test the HV out transistor, that should be Q5A02 (was this you where talking about?), effectively if you do not find anything else that would be worth replacing as a last resource.
The fyback and deflection yoke can be part of the problem test them thoroughly.
Do the adjustment procedure first, following the service manual
I assume that you have the complete service manual, I uploaded a copy here, just in case.
Regards
Posted on May 29, 2009
My 1992 mitsubishi eclipse engine is shaking
firstly is it petrol or diesel? Petrol try looking for a shorting out HT (plug lead) or that you have the leads on in the right order could also be a duff spark plug or EMU problem, check the leads and plugs first and also any wires going to coil unit. If its diesel then its probably an injector fault.
May 26, 2012 | 1992 Mitsubishi Eclipse
Model vs60707 projection tv. used to turn off when got hot,then turn back on. placed fan in front,would stay on,now hear relay clicking on and off with no powering off.
You will need to replace the STK ICs,they are Big Black ICs and will have Part Number on them STK392-570.
Mats Electronics has Parts 1-800-628-1118
If you are unable to Solder you can ship board for repair to PTS 1-800-844-7871
Jun 29, 2011 | Mitsubishi VS-60707 60" Rear Projection...
My mitsubishi tv vs60707 turns off as soon as I
These are bad about bad capacitors in the power supply and main pcbs. Unless you are good with MAJOR chinese puzzles, leave this one to a pro.
Oct 12, 2009 | Televison & Video
Finding a Capacitor for TV VS60707
Mouser electronics
Give them a call and give the information. They will have a replacment.
Jan 23, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Need signal board
u can get the require parts at www.partstore.com just insert the proper model and select the perfect brand in the link and the required part will be shown with its present rate.u can also order from this link.
Jan 06, 2009 | Mitsubishi WS-65819 TV
Mitsibishi vs60707
This a deflection problem. Both 2-3 and 2-4 are deflection. Most likely a verticale problem. a tech will need to fix it.
Mar 15, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv flutter
If your going to do the repairs yourself you can probaly get by fairly cheap, but service techs usually run between 3 and 6 hundred for video problems sounds like a capacitor issue. If you need a service manual and unlimited support for your set go to this link. Its 10.99 for the manual the supports free. They will mail it unless you return to the site and request that they email it along with the instructions on how to obtain the chat support. I am one of their support Techs, Hope this helps.
http://servicemanuals.vstore.ca/
Jan 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
No picture only sound
this error is mostly caused by a defective line output transformer T511 (partnumber 1-453-308-31) and line output transistor Q533 (partnumber 9-948-014-40).
Also resistor R518 (2k7, SMD) could have been damaged.
All components are located on the main (A-) board.
Jan 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue Screen
Sounds Like Bad Tuner,Try Running Audio Video Jacks in,Also Replace your Cable wires ttech
Jul 29, 2007 | Mitsubishi WS-55313 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
