Question about Epson Stylus CX9400 Photo Printer
Computers not recognizing printer
I have a epson cx9400 that I use for my business and yesteday none of my four computer recognize that it is plugged in. I thought maybe it was the USB cable (only way to hook it up) so I went out an got a new one, nothing. Any ideas, I have work backing up on me.
  • meteshadow May 11, 2010
    you sure it works? it does own tests ?
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Check the router or whatever hardware you use to connect the 4 computers to the printer. I use a USB Share Switch for 2 computers and 2 printers. Switch can be found at Amazon.com and other vendors.
Posted on Jun 23, 2009
I cleaned printer heads, now error m69, cannot recognize ink cartridges
Make sure that the cartridges were not dislodged or that contaminants have made there way up onto the contacts. Also ensure that your using carts with part number 69 for all four or (68 on black if using hi cap)
May 06, 2010 | Epson Stylus CX9400 Photo Printer
Just purchase and set up Epson Stylus CX9400 Fax Series. States "Cannot recognize ink cartridges." It also has a RED box with a Y and a YELLOW box with a Y both have same number (69) next to them Removed...
Make sure cartridges are part number 69 on all four or 68 on the black if its the high cap cart.
Also check the carts contacts and the machines contacts in the cartridge recetacle for contamination or damage.
Apr 27, 2010 | Epson Stylus CX9400 Photo Printer
I got an Epson CX9400 Fax and it won't print?
Hi!
Have you installed the necessary software already? The driver is needed for the connection between the computer and the printer. You might want to also check the physical connections like the USB cable or other cables which connects the device and the computer.
Sep 17, 2009 | Epson Stylus CX9400 Photo Printer
Why is my xp not communicating w/my epson stylus cx9400 fax series. The software is already install but the computer says that there is an undentify device connected to the computer to unplug the device...
try to connect the usb cable into another port on your computer, if still doesnt recognize, you should try it to another computer. if it works, then theres a problem with your computer, if not, you should try to use another usb cable or use another connector like a printer cable
Aug 16, 2009 | Epson Stylus CX9400 Photo Printer
ST-500 not recognized with Epson CX9400 printer
Printer is draining USB power resource. Add a powered USB hub and run drive off of that.
Jul 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
Apr 05, 2009 | Epson Stylus CX9400 Photo Printer
Error code
Troubleshooting & User Manual for Epson CX9400
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90753
Dec 26, 2008 | Epson Stylus CX9400 Photo Printer
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
Epson CX 3200 - twain error scanner not recognized
Click HERE for a troubleshooting guide
Click HERE for drivers and documentation
May 26, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
