Carrier 38BRC036 Air Conditioner
Problem for Carrier 38BRC036 Air Conditioner
Outside unit won't run
By nbtrotter on May 29, 2009
Last winter a Repairman came to my home and replaced the control board on my carrier home unit with model 325878 751 board. He took the manuals and is now out of business. It is now hot and the outside unit does not come on when the unit tries to cool the house. Obviously forgot to hook up a wire. My question is which one and where.
Clarification Request
Posted by ACSvcTechFL on Jun 01, 2009
Sorry i didn't read it properly the first time. It's early here
Try opening the service panel and just inspecting for any loose wires, and let me know if you find any
I need some more info on this problem.
If you turn the system to cool does the outdoor unit come on while the indoor doesn't.
Or is the Thermostat blank.
Solution #1
posted on Jul 21, 2009
Not Rated)
pillarair
Rank: Guide
Rating: 95%, 2 votes
If the inside unit is running properly, there will be a yellow wire (or blue) from the thermostat down in the furnace that needs to be hooked up to the Y terminal also there is a red and white wire in the same place in the furnace coming from the outside unit, one goes to the Y terminal also and the other would go to the C terminal in the furnace. Otherwise you may have a bigger problem.
Was this helpful?
Yes
No
Popular Solutions for Carrier 38BRC036 Air
Questions and Unsolved Problems for Carrier 38BRC036 Air
Do you recommend Carrier 38BRC036 Air Conditioner?
Answer
Answer
How to fix LG air con error code 48?
Answer
easy wiring diagram air conditioning
Answer
I have just moved into a new house & the previous owners have not left me the operation... (More)
Answer
hi i am an installer and have a midea 1hp inverter where when it is off the indoor unit has a low... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , CA
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
