Question about Compaq iPAQ MP2810 Multimedia Projector
The fuse directly is broken when the power is on
I HAVE A IPAQ MP2810 COMPAQ I think that the 5 terminal voltage regulator attached to the PT VIP DCDC converter is fried, I have a similar dilema, can someone have a look inside of there projector to give me the ID details of this voltage regulator please it would be greatly appreciated
  • wieyabuggama Jun 08, 2009
    Unfortunately the little beggar has literally exploded, leaving no possible means of Identification, but if you have the same projector model, could you open it up and take down the numbers off the component for me. The Voltage regulator is a 5 leg black plastic chip about 1cm square, it sits on a daughter board just inside the projector above where the fuse is located, if you require clarity on location, item, i would be happy to post a photo, just say
    New Friend:
  • 5 Answers
The 5 leg black plastic chip part is a "VIPer100a" I have one with the same problem, but mine burned up pcb tracks and other parts.
Good luck.
Peter
Posted on Sep 21, 2009
Will not power up
POWER SUPPLY POSSIBLY HELD IN STANDBY FOR VARIOUS REASONS
Apr 16, 2013 | Compaq iPAQ MP2810 Multimedia Projector
I tried using 3 AA NiMH batteries (total DC V=4.2, 1600mA) as a backup/charger for my HP Ipaq 612c battery. I inserted a resistor (4.7 ohms) in the circuit to reduce the current. The red light charging...
You built one of these too, eh?
Yes, there can be a problem doing this. First off, 3 AA batteries does not equal 4.2 volts, they are 1.2volt nominal so 3 * 1.2 = 3.6volts. When they are just off the charger, terminal voltage will be closer to 1.5v, so 1.5*3 = 4.5 volts.
Using ohms law, E=I * R, we can find your current as I = E / R or I = 4.5v / 4r7 as .95Amps (almost a full amp) that you would see worst case. The resistor is doing nothing for you.
The reason that the charge light blinks intermittently is because the charge controller (lithium battery, right?) is pulsing due to low voltage.
Try this: Take *6*, yes, 6, AA batteries, your choice of chemistry, and put them in series. That will give you a nominal (alkaline) voltage of 9v. Connect a low dropout 5v regulator such as an LT1117-5. Then you will be able to use your battery backup much more effectively.
On a different note, I used 4xAA (NiMH) and powered my ipaq 3650 directly. Worked great. Your mileage may vary though.
Aug 27, 2010 | Cell Phones
Compaq MP 2800
Hi there
Does your Projector support Windows Vista ?
Mar 07, 2008 | Compaq 207685-001 - Microportable...
Problem with Compaq IPAQ PSU
Re-check the regulator. and i think the problem is in secondary. also check the resistor that supply 12-18V
on the regulator.
Nov 16, 2007 | Compaq 90W Power Supply IPAQ PC / Legacy...
hi all... i have this projector and it boosts up flashes the blue screen and sometimes the projected image too. then goes to standby mode.
I have managed to keep it going enough to see the problem for myself. Here is what i did.. lye the projector on its left side while a cool blower blows through the left side of the lamp housing. fire it up and it will stay on. I went to the menu and did a factory reset as well as lamp hours reset. checked the lamp hours and it was at zero. so its never going to stay on for long for one reason.
As the lamps get older the emit more heat and therefore cause the unit to shutdown. so if you want it to work your going to have to order that lamp. The cheapest i found is from austrailia link off ebay below.
http://cgi.ebay.co.uk/COMPAQ-HP-MP2800-MP2810-MP-2800-MP-2810-Lamp-L1552A_W0QQitemZ280387113761QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item41485fd321&_trksid=p3286.m63.l1177
last link is for the manual found in this forum but not clear on how to get it.
http://h10032.www1.hp.com/ctg/Manual/bpj07855.pdf
Hope you get a good result bulb on order.
AndystUK
vote me happy
Oct 19, 2007 | Compaq iPAQ MP2810 Multimedia Projector
No power to projector
Generally when the globe goes end of life and needs replacing the unit will fail to power up. Try another globe if you have one spare.
Sep 10, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Ipaq voice file help
I use MP3 Voice Recorder v1.21 on my ipaq WinMobile2003. Very configurable, creates high or low quality mp3s which may be attached, moved, burned on CDs or sent on floppies even. And, it's free.
Sep 12, 2005 | Compaq iPAQ H3850 Pocket PC
Compaq iPAQ MP2810 Multimedia Projector Logo
505 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Greg Cann
Greg Cann
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
