Question about Adobe Photoshop 7.0 for PC
Picture how can i perfect size of photo canver other size
  • 34 Answers
Do you mean a standard phote size ie 6 x 4 inch?
if so goto the file menu
select new
goto the plldown menu and select 6 x 4 size
create your picture
Posted on Nov 10, 2007
Large pictures don't display
Many digital photo viewers can only display photos of a certain size or less. Check your owner's manual, or find the manual online, and it should tell you what the upper size limit is for your viewer.
Jul 04, 2014 | Kodak Digital Photo Viewer
Why are my pictures blurry on my 8ff2fpb 37
I had the same problem with my photo frame but was happy to find the answer to the problem on the website for my photo frame:
You need a resizing program to resize all your photos to the recommended size for your frame. The program I used is:
and here is the step-by-step instructions on how to resize all the pictures at once:
After that all the pictures, even the ones with lower quality displayed perfectly fine on the photo-frame.
Apr 24, 2012 | Cameras
I have a datatraveler 4gb stick how many photo will it hold
That is not exactly to calculate. It depends on the stored image sizeand quality.
Small pictures could be 400KB a piece, but large ones easily can go up to 6GB
a piece. If you know thye avaerage size of your pictures, you can calculate it.
Aug 28, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
My photos are downloading at a low resolution (72) and a small photo size (6x8) How can I change this?
I set all my cameras to the maximum number of megapixels and "fine" quality. You never know when you'll capture that perfect picture and want to blow it up to maximum size. You can make these changes in the camera menu.
Jan 05, 2010 | Cameras
Epson problem
Here is the download page
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
All in one
this can be a tricky issue, just like getting pictures to print out the size you want. basically, you either need a program like Adobe photoshop where you can change the size of the image, or you need to scan them in at a higher resolution. you can set this in your scanning software before you scan the photo. to give you a rough example: your laptop screen might have a resolution around 1280x720, if scan in a photo at 640x480, it will only cover around half your screen. This is the simple way to do it. If you have photoshop, you can open any sized picture and change the picture size (sometimes you will loose quality). hope this helps :)
Jan 21, 2008 | Office Equipment & Supplies
How do I make an image file smaller so I can send it by e-mail?
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer". Changing the size of an image file 1. Start up the Viewer and select the folder containing the image you wish to send. 2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window. 3. Select "Image size" in the "Image" menu. 4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button. 5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
Aug 30, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Adobe Photoshop 7.0 for PC Logo
48 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
