Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water keeps coming back out of washer drain
The drain in the back of my washing machine keeps on spitting water back out in the beginning
  • honeymokey
    honeymokey May 11, 2010
    Start from when you turn machine on and give more details.
  • 332 Answers
DRAIN HAS A SLIGHT CLOG AND BEING SINCE YOUR NEW WASHER IS MORE POWERFUL AND EFFICANT YOU MIGHT EVEN HAVE TO RESIZE THE PIPE FROM THE TRAP TO THE DRAIN THIS IS CALLED A STAND PIPE SHOULD BE 34INCHES TALL FROM TRAP IS WHAT IS REQUIRED UNDER CODE TO KEEP THIS FROM HAPPEING
Posted on May 29, 2009
Why Does all the Water Drain while the machine is washing and soon the entire water drains even though its in wash
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Apr 05, 2015 | Washing Machines
GE gtwn5050mows water spitting while filling
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
May 17, 2012 | GE Washing Machines
The water is entering the washer, but is not
Either the drain hose is too far into the drain or drain hose is too tight in the drain . Make sure the drain hose is NOT taped to the drain (to keep the drain pipe from overflowing ) All of these will cause a syphon problem , where water will be "pulled out" of the machine by your sewer line , as water is filling your machine for wash (usually rinse cycle).
Sep 10, 2009 | Kenmore Elite 45986 Front Load Washer
Washer first begins to pump water, it comes out of the drain pipe
Laws of mother nature are the pipe is clogged or the size of the pipe is too small for the volume of water.Sorry I can't be moe helpful.Need help majortom350@yahoo.com
Aug 22, 2009 | Washing Machines
Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine water comming out from bottom
Check the hose that connects from the tub to the water pump. Next time you do a load remove the front panel and set the machine for a "small load" so there won't be alot of water. When the machine begins to agitate shut off the timer and move it to the final spin mode and turn it on. Here is where you want to watch that hose (maybe with a flashlight) as the tub begins to spin and the water is being pumped out, focus on where the hose connects to the drum. Usually as the spin increases the vibration will cause the hose connection to become loose and water will start spitting out. If you don't see any leaks in the hose, check the water pump itself. NOTE: DO NOT PUT YOUR HANDS IN THE MACHINE WHILE IT IS IN OPERATION! JUST LOOK IN AT THE HOSE, DO NOT TOUCH ANYTHING AND KEEP YOUR HAND BEHIND YOUR BACK! THE OTHER HAND ON A FLASHLIGHT FROM OUTSIDE THE MACHINE.
Feb 18, 2009 | Maytag Dependable Clean Top MAV5920EWW Top...
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Jan 31, 2007 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
139 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
