Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
I need to repalce the elctrical supply cord and water supply line to my Fisher & Paykel DD603 dishwasher, but I'm unsure as to how to remove the terminal box cover. Could you please help? Thanks.
I need to replace the electrical supply cord and water supply line to my Fisher & Paykel DD603 dishwasher but I'm not sure how to remove the terminal box cover. Could you please help? Thanks.
  • 332 Answers
THIS IS SIMALAR TO THE BOSCH UNIT, IF THERE IS NO BOTTOM COVER TO REMOVE YOU NEED TO TAKE THE SCREWS OUT OR THE TOP INSIDE THAT HOLD IT TO THE COUNTER TOP, PULL THE UNIT OUT SLOWLY, TURN OFF THE WATER SUPPLY SHOULD COME OFF THE HOT SIDE OF YOUR FEED LINE TO THE FAUCET UNDER THE KIT SINK, THE WATER SUPPLY IS ON THE LEFT LOOKING AT IT AND THE ELECTRIC IS ON THE RIGHT IF YOU CAN PULL IT OUT ABOUT 8 INCHES YOU CAN GET TO BOTH CONNECTIONS TO BE ABLE TO DISCONNET PULL OUT ALL THE WAY GET BEHIND IT AND CHANGE WHAT EVER YOU NEED TO
Posted on May 29, 2009
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Oct 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Continuous beeping and lock is intermittentyl showing on DD603, have tried turning off power, holding in lock button, turning off for 10 mins etc. CAnt stop it and driving us insane!! Can anyone hlpe us...
you need to Call the Fisher & Paykel customer service line and tell them that your Unit is Experience a Power Malfunction Usually its related to water leaking.
Aug 02, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel Dishwasher DD602 Controller
def, not the same piece, you can call the manufacture for the repalcement parts, if you dont have a local parts distributer( f&p direct best bet)
Feb 11, 2009 | Fisher Dishwashers
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
175 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
