Question about Alpine CDE-SXM145BT Advanced Bluetooth CD SiriusXM Receiver
CHECK TUNER on Sirius XM
Put on Sirius XM and CHECK TUNER is displayed and no radio audio is received
    New Friend:
Holding the red reset button solved the problem
Posted on Feb 22, 2017
    New Friend:
Ours was corrected by removing the faceplate and holding in the small red reset button that is located about halfway across the front
Posted on Apr 04, 2015
3 Suggested Answers
SOURCE:
LVT7857
  • 116 Answers
SOURCE: Alpine CDA 9835
Sounds like you lost the power on your memory wire (yellow) some how. Check power on both the red ad yellow and make sure that you have 12v going to both.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
SOURCE: XM Radio Receiver
if you can find a Alpine TUA-T020XM that is a direct fit but they are scarce
Posted on Sep 04, 2010
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
Oct 14, 2012 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
Jan 14, 2012 | Panasonic CQ-DF783U CD Player
The radio says it's Satellite ready, but when I hit the search button I do not get a Satellite option. When I called Sirius/XM to switch service from one car to another, they said that I must now also...
No it is satellite ready, meaning you need to add atuner to the stereo, but you can use the stereo to control the tuner. Again, a seperate tuner will need to be bought and installed. Good Luck.
Sep 08, 2011 | Kenwood Kdc-bt645u Car CD/ MP3 Player
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
I don'tknow how to use the satellite radio...
Got this off the crutchfiel web site.
Item #700XMSON1 $129.98 This XM Direct 2 package includes everything you need to add XM Satellite Radio to your compatible Sony receiver: an XM Mini-Tuner, a CNP2000UC universal adapter, and a Sony connector cable. The Mini-Tuner connects to the universal adapter, then you use the connector cable to hook up the adapter to your Sony receiver.
Use your home computer to program the universal adapter for your Sony receiver — you can reprogram this adapter to work with another brand in the future. Once connected, you'll be able to change channels and see programming information on your stereo's display. You can also use the included XM Mini-Tuner with your XM-ready home receiver or in another vehicle with a compatible dock.
A computer running Windows XP and Internet Explorer is required. The unit is not compatible with Windows Vista.
Note: A subscription to XM is also required — learn about XM's programming. Satellite radio service is available only within Canada and the lower 48 states — not available in Hawaii or U.S. territories. Portable reception may vary by location. If you have questions about the proposed XM/SIRIUS merger, read the XM Customer Promise. To view this file, you will need the Adobe Acrobat PDF reader.
Apr 16, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
Satellite Radio
 Yes, but it will require a tuner adapter so that your deck will properly recognize XM. However for my deck I noticed that "Sirius" will still be displayed as the satilite provider on the display menu. Confusing but don't cause much concern.
May 22, 2008 | Car Audio & Video
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Alpine CDE-SXM145BT Advanced Bluetooth CD SiriusXM Receiver Logo
5,801 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
