Question about Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver
The control pad/dial isn't working properly. There doesn't seem to be enough juice to get sound. The green light is on when plugged in but its not transferring sound from the source to the speakers.
Bose Companion 3 Series II Multimedia Speakers.. The control pad/dial isn't working properly. There doesn't seem to be enough juice to get sound. The green light is on when plugged in but its not transferring sound from the source to the speakers??
Oh ok. I'll chek the input again Thanks
Posted on May 30, 2009
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
97 chevy blazer isn't getting enough juice to start
You may have a dying cell in the battery. It will charge and seem OK but won't stay charged for long. Try a load test of the battery
Mar 23, 2013 | 1997 Chevrolet Blazer
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
Can't turn it on. Power digital readout doesn't work.
Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Nov 30, 2011 | Bemis 821 000 Humidifier
Very low volume HK 695-01
There are several ways in which you can increase the volume.
First, the most obvious way is to use the volume control attached to the speaker unit itself. If that isn't working, there's also an icon in the lower right-hand portion of the task bar in Windows. Simply click the ^ button, select the icon that looks like a speaker, then drag that up to your desired preference.
If that doesn't work, click on Start, go to Control Panel, click on Sound, then search for your Speakers in the "Playback" tab. First, make sure it's set as your Default Device. There should be a green check mark in it. Double click on those, select Levels, then make sure Play Control is set to maximum.
If that doesn't work, then check the settings on your Sound Card. Make sure the wire going into the back is plugged in properly. You may need to update your sound card drivers. If you aren't sure who the manufacturer of your sound card is, you can find out by going to Start > Control Panel > Device Manager. The Manufacturer will be under Sound, Video and Game Controllers.
Once you have that information, you can go to the Manufacturer's website and update the Drivers. If this doesn't resolve the issue you are experiencing, or if you require more specific / additional information, simply respond to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 03, 2011 | Harman Kardon HK695 Computer Speakers
My 2004 alero works just fine all the time, but today leaving for work, it won't start. Just got one click and nothing, no trying to turn over. It seems like the dome light works, maybe dimmer than...
Sounds like a battery. Battery probably has enough juice to make the dome lights work, but not enough juice to turn the starter. Have your battery checked out.
Feb 15, 2011 | 2004 Oldsmobile Alero
Is it ok to charge my controller on laptop/pc
There isn;t a reason why you shouldn't charge using a laptop/pc, did a bit of resaearch and many people claim to be charging thier pads via a pc's usb,
I tried it on mine and it didn't work, it recognised the PS3 pad and installed it as a game controller, which was pretty cool but it wouldn't charge, haven't tried it on my mac yet . If it doesn't work first time try a diff. usb port on your laptop pc, as sometimes its certain usb ports on your system that carry enough juice to power a device
d:)
Jul 31, 2009 | Sony DUALSHOCK® 2 Analog Controller for...
A/C Heater control doesnt work.... trips the antilock light
5 volts is not enough to run the blower sound like your blower resister is shorted out and back feeding the system did you check it?
Nov 02, 2008 | 1997 Chevrolet S-10 Pickup
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
1,193 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
