Question about HP LaserJet 1100 Printer
Hp laser jet1100 prints white lines
My HP laser jet 1100 Prints white lines(about 12 to 16)per page.
I have changed the cartridges but remain unsolved.
Please reply me as soon as possible.
Thanx
The Hp user
  • ejazmusavi May 29, 2009
    the distance is about(3 to 6cm )from the first to th next
  • ultimitloozr May 11, 2010
    Measure the distance from the first defect to the next. This will help determine which roller is causing the problem.
    Novelist:
  • 125 Answers
Hi ejazmusavi:
Try this.
Toner/developing cylinder 37.7 mm (1.48 inches)
Toner/primary charging roller 37.7 mm (1.48 inches)
Heating element 56.5 mm (2.22 inches)
Transfer roller 45.2 mm (1.78 inches)
Pressure roller 62.8 mm (2.47 inches)
Toner/drum 75.4 mm (2.97 inches)
Feed roller 55.1 mm (2.17 inches)
Hope this helps
Posted on May 30, 2009
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
The print quality of my HP 1100 printer has suddenly deteriorated to the point where the type on MS Word, MS Excel, and CAD applications is very faint and nearly illegible. Type from web pages is even...
It can be that your lower hot roler are broken so there are no presure agains the hot roler,or your hot roler has toner burned on it or you need a new lazer unit.
Oct 06, 2009 | HP LaserJet 1100 Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Hp 3745 desk jet problem
check whether its printing the test page properly directly from the printer not from the pc.for that print
1)just ON the printer
2)press the ON button
3)do not leave the ON button and lift the cover of the printer completely up and down 4times.
4)if you want to change the cartridges which front cover you will lift ,that you have to lift 4times up and down by pressing the ON button ,then leave the ON button the printer test page will come out of the printer .
5)keep the paper in the tray.
6)check that printout if its proper the printer is perfect
7)if the print is improper then the printer is having some problem.
8)also try changing the cartridges and see if its same or better prints comes out.
thanks.
Sep 18, 2008 | HP DeskJet 3745 Printer
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Feb 29, 2008 | HP LaserJet 5550dtn Printer
HP LaserJet 1100 Printer Logo
200 people viewed this question
Seeker5211
Seeker5211
