Question about Watches
Bad IMEI please help me how to repair my phone with bad IMEI. i try it in JAF box box but still the phone will automatically off after 20sec. i already used the patch method but the result still the same...... could you please help me to solve this problem? by the way my phone is Nokia 6610i. Thaks!
0 characters
1 Points
Hi,I brought yesterday a Gucci Pantacon that's mechanic, in this morning I wanted to change the time and sadenly the mechanic thing stop moving when I was shaking the watch!! Any solution please?
I hope you did not shake it too bad. If I had a new watch and it stopped working O would go straight back to the shop. I'm must be defect, or it is not an automatic and you should try to wind it up.
Jun 02, 2014 | Watches
Skagen watch date won't automatically change.
That sounds like a bad circut so you are going to need a service. Should cost between $50-$100 therefore you may want to consider replaceing it as the repair costs would be close to the replacement costs.
Oct 23, 2013 | Watches
Invicta 8926A gains about 2 or 3 minutes after winding.
Send in for warranty repair with a description to Invicta
Oct 12, 2012 | Invicta Automatic Pro Diver 8926A Wrist...
Please help My seiko 5 superior 23 jewels is moving too fast,every 1 hour it'll be 2 or 3 minutes sooner than the other watch, how to fix it? thank's
mcdevito75 here, You could have a bad hairspring or faulty mainspring in your seiko, look for a small watch repair shop im yyour area for repairs.
Aug 04, 2010 | Seiko Watches
My watch is never right
Exactly what Kind of watch do you have?
Is it a quartz or automatic?
In either case, from your description it sounds like you will need to take your watch in for repair. The difference is whether or not it's worth it. Personally I would recommend fixing almost any automatic. Quartz watches are a different story. Although they can be repaired as well.
Find a repritable jewelers and inquire about who does their watch repairs.
If you would like more specific details please respond with the make and model of your watch.
Hope this helps.
Jan 01, 2010 | Watches
I have an automatic watch that i don't wear that
Does it work when you wear it? If it does on those occasions then no harm no foul!!
Oct 06, 2009 | Rolex Daytona 116528 Wrist Watch
Condensation in crystal of eco watch
If there is water in the watch, it's going to quit working sooner or later. If sooner, then the watch (at least the back) will have to be opened anyway. If later, then there will likely be some rust that could cause the watch to never work again.
In the meantime, I'd advise putting the watch near some dry heat -- like a radiant room heater, or maybe a hair dryer. Don't "burn it up" trying to dry out the water. You don't want the crystal to melt, etc.
Water in a watch is bad. The best solution would be to have it repaired now.
I hope this helps!
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Citizen Eco-Drive BL006056H Wrist Watch
Battery Not Working
Take your watch to a reputable watch repair ( NOT A JEWELER) you should be able to find one in the phone book. The price (depending on where you live) should be between $8.95 and $12.95. Tell the store to CHECK your battery, NOT replace it at first because that is exactly what they will do , and sometimes it"s not the battery that is bad . You may a mechanical problem and when you change the battery, it will run good for about 3 weeks and than it will go back to having the same problems again and you've just waisted your money. If you have anymore question, please feel free to ask, I will be glad to help you. Good Luck!!
Aug 12, 2008 | Watches
Try to use a piece of tape to cover on the battery, this is a way to do the insulation to prevent bad contact.
Jun 19, 2007 | Kenneth Cole Reaction Square Steel Case...
Watches Logo
251 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
