What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
the E4OD- (electronic, 4 speed, overdrive) transmission and the C6- (3 speed automatic) transmission may have the same bell housing pattern, so it may physically bolt up, but the van was setup for the electronic trans, so if you put it in there it will set codes and turn on the check engine light, and the electrical connectors will have nothing to plug into. I would try to find an E4OD and replace it, rather than swapping it. What problem does your E4OD have?
amount of fluid in an e4od transmission
