Wiring diagram for a Carver amp, preamp and A/D/S subwoofer
I am currently living in Asia and brought over my Carver Amp, preamp, A/D/S speakers and subwoofer that I purchased in the US in 1990. All of the equipment is in working order (some has been repaired here) and all has been recently converted over to 220 volts. My problem is I cannot remember the wiring diagram and hookups used for the system when I had it running in the US. The local audio people here tell me to just hook up to the low frequency input on the subwoofer and when I do so, the sub has sound coming out when I turn the volume down from the control on the preamp. I would greatly appreciate it if anyone could help me out on how to hook the equipment back up for the best sound. Carver TFM-55 Amp Carver CT-17 preamp A/D/S Sub 12 subwoofer Thank you in advance for your help!
techman
  • 3130 Answers
SOURCE: woofer problem
If I am not mistaking here, you need a self powered subwoofer to use with this unit. Those are line driven outputs for this unit. Make sure there is a wall plug on the sub that is plugged in. Good Luck
Posted on Jun 07, 2007
  • 113 Answers
SOURCE: Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Posted on Aug 09, 2007
SOURCE: Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Posted on Dec 02, 2008
mrwtech
  • 59 Answers
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
MrScary66613
  • 1990 Answers
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Posted on Jan 31, 2009
Why does my carver receiver keep blowing the 4 amp fuse??(4amp 125v)
check speaker wires for shorts. verify correct speaker impedance (if amp if for 8 ohms, don't use 2 ohm speakers. Make sure not overheating issues with junk on top of amp.
Dec 29, 2009 | Carver Audio Players & Recorders
I have just bought a new bose 901 speaker system which included equalizer. I am not sure how to connect the equalizer to my receiver Denon 3808. I need help.
http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Be advised, this speaker system requires its own dedicated two channels of signal preamplification and power amplification and the required Active EQ is not to be used in the signal path of anything else. I have them as my Main Left and Right Speakers in a 7.1 set-up, but I'm using a 5-channel external Carver Power Amp to drive them, a sSb and the Rear Surrounds. The Active EQ is between the Receiver's Main L&R Preamp Outputs and the two Carver Amp channels that drive the 901's. Don't think you can just add the 901's into your living room and enjoy multichannel sound. Search around fixya, I have written extensively on this subject.
Nov 18, 2009 | Bose 901 VI Main / Stereo Speaker
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
Aug 25, 2009 | Bose 901 VI Main / Stereo Speaker
Wiring diagram/ amp hook up
without preamp outputs,you need to get a speaker line matching transformer.it takes the speaker signal,reduces the level,puts it thru a low pass filter if it is for a subwoofer. it basically is a tranformer resistor network that drives a set of rca plugs that will go into the amp. the only tricky part is noise,speaker lines have a poor signal noise ratio if you amplify them.
May 22, 2009 | 2009 Ford Focus
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
Latest model surround receiver for bose 901 speakers VI
I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
Mar 20, 2009 | Bose 901 VI Main / Stereo Speaker
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Carver TFM -35
possible short in speaker system. Disconnect the speaker to that channel. if it does not click off then you have a short outside the amp in your wiring or in the speaker.
Sep 17, 2007 | NAD C350 2-Channel Amplifier
1,096 people viewed this question
 Grubhead
Grubhead
