Question about Canon Office Equipment & Supplies
ERROR: TONER CARTRIDGE NOT SET, RESET CARTRIDGE
ERROR ON TONER READING: TONER NOT SET - REST TONER CARTRIDGE TONER IS NEW AS OF LAST WEEK AND HAS MADE APPROX 50 COPIES, STILL ALOT OF TONER LEFT IN CARTRIDGE. I HAVE TAKEN IT OUT AND PUT IT BACK IN SEVERAL TIMES AS WELL AS SHUTTING MACHINE OFF SEVERAL MIN AND TURNING BACK ON??? STILL NO PROGRESS - PLEASE TELL ME WHAT IS NEXT COURSE OF ACTION. THANKS-CHRISTINE
  • eric400 May 11, 2010
    what kind of machine is it? is the cartridge oem or remanufactured?
  • 4 Answers
SOURCE: OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
Posted on May 23, 2008
checkitright
  • 1362 Answers
SOURCE: xerox XC1045
Here is the solution:
https://www.partsdrop.com/store/info.php?info_id=XC810ins&osCsid=9b1b49fedd585d440cde474465a2c980
Posted on Jul 15, 2008
  • 92 Answers
SOURCE: crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Posted on Oct 16, 2008
checkitright
  • 1362 Answers
SOURCE: printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Posted on Oct 30, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I just read that random dots being printed on the left side of all my documents means that i need to change the toner. I just changed the toner last week or the week before. Is this something that I call...
Hi
Well not often the problem is same, usually the toner cartridge will have 2 bins 1 is the hopper which holds the un-used powder and the other is the Waste toner bin which holds the waste powder. When it is full and there is no place to escape then the powder spills on the paper. But if this happens then you can just bang your toner lightly and in this was the air pockets in the powder is clear and spill will stop automatically.
PLEASE RATE MY SOLUTION
Jul 06, 2011 | HP LaserJet 1020 Printer
I'm getting an error code 59.60 on our HP 3015 printer. Last week I had to change the toner cartridge because we were getting a smudge on one side of the print. Could this be related? A bad printer...
Error 59.60 is an issue with the black cartridge motor starting up.
Check that connectors J5006 on the black print-cartridge drive motor and J208 on the driver PCA are seated correctly. Replace the black print-cartridge drive motor. Replace the driver PCA.
Feb 28, 2011 | Office Equipment & Supplies
I have put an "compatible toner cartridge in my Samsung CLX-2160N
By using refill cartridges there is no easy way to reset your printer to except it. The chip located on the cartridge is letting the printer know that the cartridge is emtpy. The solution is to buy a brand new cartridge and this will clear the message for you.
Jun 04, 2010 | Samsung CLX-2160N All-In-One Printer
Error code"toner exhausted" what to do?in samsung scx 4300
toner exhausted = the toner has been used all up, buy a new one.
It's something like
http://www.tronix.ro/toner-samsung-scx4300-p-9783.html
May 27, 2010 | Samsung SCX-4300 Monochrome Laser...
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
May 10, 2008 | Brother HL 1440 Laser Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
PagePro 1350W
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Dec 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
102 people viewed this question
old marine
old marine
