Question about Yamaha RX-V661 Receiver
Yamaha front panel display dim
Yamaha rx v661 front display is very dim, it suddenly lost luminosity. how to fix it.
Yamaha RX-V661 LCD / Front panel.
Symptom: when you first turn it
on, you can see a VERY little light but after 5 sec, you cannot see it anymore
or for most of us, we started using a flash light. Here is the summary of the solution and I know that it works
because I fixed it today 3/16/2011, 30 minutes ago.
As many pointed out that there is a
"light" 12v - 14v in the back but there is NONE. How do I know? I listened and searched and
there are NONE. The whole LCD in the front is air seal like a light bulb so it
is a light bulb already. Also, you might
see a little burn/gray smoke on the left hand side, don't worry about it
because if the light comes on, it stills work but not enough power. If the LCD
is broken, please don't try by the part and replace it because by the time you
read this, the parts and labor cost as much as buying a new one (on eBay and
not Best Buy).
Problem: in the middle of the unit near the back near the "surround
sound back", there are 3 capacitor rated at (2 units) 35v 220uf 85'C and
(1 unit) 50v 220uf 85'C. What Yamaha did wrong, base on my guess is that they
put the 85'C too close to the heat sink.
The heat causes the capacitor to slowly blown that is why you still get
your power to the LCD but not enough.
Solution: remove the top, unscrew EVERYTHING in the back and there are about 20 ~ good luck. For
those that don't have good memory, please take a picture. There are many plugs inside
that you need to unplug before you can remove 1st layer (audio/ video input)
2nd player (HDMI and Optical input), the last layer you will see 3 capacitors that
are kind of "blown" up (google "bad capacitors" pictures or
video). Remove them then replace them, which you can Google this on tube and
they should teach you how. It was very easy for me but then again, please don't
try to do it if you cannot even change your car oil or build a computer because
I believe that is the difficulty level.
solder iron: $9-$20 get it on eBay or radio
shack
(2 units) 35v 220uf 105'C and (1
unit) 50v 220uf 105'C or what I got was (3 units) 50v 220uf 105'C
I keep the 220uf the same to be
safe but increase the voltage and heat to increase the life of the capacitors.
Good luck everyone,
Posted on Mar 17, 2011
    Scholar:
  • 127 Answers
You can change the LCD brightness in the Setup / Display menu.
Posted on Mar 02, 2010
I have also the same problem, brightness was full when display was very dim. Now display is black but all other works correct. Probaby I have to buy new display.
Posted on Apr 21, 2010
Wrong remote
no but you can change the settings from the front panel of the unit.
Feb 12, 2014 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 powers on when I hit the power switch. After two seconds it goes to stand by.
try holding the 'straight' and 'audio select' buttons and press power. What does it say on the front panel? Should say some kind of protect: I, DC, PS. This will help narrow down where your problem is.
Oct 15, 2013 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Sep 05, 2009 | Yamaha RX-V661 Receiver
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
WII
Had the same problem- but had success when I connected the wii to my DVD player, which then HDMIs through the reciever and then HDMI to my projector.
Dec 25, 2008 | Yamaha RX-V661 Receiver
Display problem RX-V661
Contact Yahama's customer support group on the web is one way to order one...accordianman
Sep 08, 2008 | Yamaha RX-V661 Receiver
RX-V661 front display problem
Excess power supply demand from the display can cause the symptoms you describe. Unfortunately, the fix will be a new display if this is the case...accordianman
Jun 16, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 polarity problem
There is no "fix" the mic is picking up a lack of bass based on room acoustics and is trying to help. There is nothing wrong. If you are using bi-pole or dipole speakers it will always show out of phase.
Feb 27, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
5,371 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
