Question about Canon imageRUNNER C3200 Copier
After replacing toner-printer won't reset
Canon 3030 won't print after we've replace toner. It seems as though it isn't resetting.
  • rjf388 May 11, 2010
    what is it saying on the copier to do???
  • DanakaDan May 11, 2010
    Did you pull tabs on the toner cartridge?
  • 149 Answers
The machine should ask you if you've replaced the relevant toner cartridge, you must answer ;yes'. Turn off the machine and then on again and remove the toner cartridge. Then re-install it and answer the question correctly.
Posted on Jul 05, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
Feb 07, 2013 | Canon New Usa Imageclass D420 Laser...
Light and dark lines on hp laserjet 3030
Replace transfer roller & check..As well as check teflon sleeve surface for any toner particles deposited on it..
Sep 03, 2012 | HP LaserJet 3030 All-In-One Printer
Functional problem sc 390 on ricoh photocopier, despite replacing drum, developer,blade,gears. after removing 9 copies it reads functional problem.
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Aug 17, 2011 | Ricoh Aficio 1018 Printer
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
No printing or copying all of a sudden
try this semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Dec 23, 2008 | HP LaserJet 3030 All-In-One Printer
Konica minolta 9J04 refill
Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Nov 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Canon imageRUNNER C3200 Copier Logo
216 people viewed this question
old marine
old marine
