Question about IBM Wheelwriter 30 Typewriter
Machine beeps, no movement, monitor missing, tried turn on off.
IBM Wheelwriter 70 beeps, but won't move...spacebar, keys, nothing. monitor is missing and already tried turning machine off and on, plus unplugged...no change
  • IBM Master
  • 3,594 Answers
Remove the batteries and unplug for 30 seconds plug in and test. Unpluging and removing the batteries causes it to reset to defalt settings.
DickyO
Posted on Jun 02, 2009
Turn the sound off of IBM Wheelwriter 3.0 Series II
The only sound you can turn off is the optional spell check feature which is done by holding down the code button (left of the spacebar) and then hitting the number 1. Any other beeps cannot be turned off.
May 08, 2014 | Lexmark Wheelwriter 6 Series II Typewriter
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps twice and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is...
Probably the key board is bad you can try my tip under WW 1000 or contact Geo. Beters Co.
@ 800-392-8085 for a key board rebuild. Tell them O'Reilly sent you.
DickyO
Apr 07, 2011 | IBM Wheelwriter 30 Typewriter
Wheelwriter gives 3 beeps when turned on. Meaning?
Try this. Remove the batteries, turn off for 30 sec. turn back on.
This will set everything to default settings. IT WILL ALSO CLEAR THE MEMORY!!!
DickyO
Mar 19, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
IBM Wheelwriter will no longer turn on. The
Not a good thing. Probably the power supply or function board.
If you are courageous open it up look for paper clips and staples on or aroud the board.
DickyO
Nov 12, 2009 | Lexmark Office Equipment & Supplies
Wheelwriter 70
If the monitor is missing as many are it's hard to tell what your problem is. Try thios remove the batteries, unplug the machine, wait 2 minites then restart thr machine. This will set everything to the defalt settings. BE AWARE THAT ALL THE MEMORY WILL BE CLEARED!
DickyO
Dec 23, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3
You probably have a broken plastic cap on the print solenoid plunger, they are available but a little tricky to install.
DickyO
Oct 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 1500 TYPEWRITER
Check to see if anything dropped into the typewriter to inhibit the movement of the carrier if noy try a few drops of WD40 on the shaft that runs thru the carrier.
DickyO
Apr 03, 2008 | IBM Wheelwriter 30 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 70 memory
You can hook up a standard computer monitor to the typewriter, but it won't recognize color, and sometimes on eBay you can find IBM POS (point of sale) monitors that will work on the typewriter. Do you still have the typewriter?
Feb 12, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
172 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
