Question about Frigidaire GLTF1670A Front Load Washer
Lint filter/can't find
I have a front load frigidaire washer and I can't find the lint filter
  • 332 Answers
THERE SHOULD BE A TRAP DOOR EITHER RIGHT INSIDE THE FRONT DOOR OR ON THE TOP OF THE UNIT MORE LIKELY RIGHT INSIDE THE FRONT DOOR
Posted on May 29, 2009
How do you change lint filter
Hello ccparish8 - Base on the model listed above on the post, washer GLWS1339EC does not have a lint filter or any of Frigidaire washing machines. However, if you are referring to replacing the lint filter on a dryer, simply remove the lint filter from the housing and reinstall in the same manner.
Feb 24, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
My whole house smells like rotten eggs when I run my washer. I have read it could be the lint trap. Where is the lint trap on the Frigidaire gallery front loader?
. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out
Aug 15, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer, it and the clothes stink.
I have read that using Nu Fresh in a few of your loads will take care of this problem.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
How do I use the dryer rack in the Frigidaire Infinity gas dryer. I can insert it but what do I do to keep the drum from rotating and tossing the rack aroung?
Do you have a lint filter slot inside of your dryer or on the top? Our rack in ours mounts into the lint filter slot and the drum turns around it and does not turn the rack. If you have a lift filter that is on top of the unit the rack may mount into the back panel allowing the drum to turn around it.
Mar 03, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washer does not fill at all
Have you checked the filter just inside the water hoses. You just turn off the water and unfastenent he hoses from the machine and you will find a little filter. It may be clogged with lint, sand, etc.
Jul 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Won't spin out on normal wash cycle
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Mar 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 41742042100 front load washer
IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
Jan 02, 2008 | LG WM2688H Front Load Washer
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Frigidaire GLTF1670A Front Load Washer Logo
229 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
