Printers
Problem for Printers
Generic problem for all Printers
Canon i560x
By lozreed on Oct 22, 2007
I have changed ink in the printer and alligned the new ink. Printer is now flashing orange light and will not change back to yellow. Tried turning off and putting back on but still there, pulled plug out still there, it will not let me print anything because this error light won't go away, can you help me get rid of it.  Thanks can you email lozreed@fsmail.net
Same Problem
Nov 23, 2008
-   I have the same problem-   Guest
Dec 27, 2007
-   i550 flashes orange 7 times then once green, status check says error "printer not responding"; also, with printer alone (w/o USB plugged in) still gives same flashing lites pattern. Tried doing EPROM reset procedure, did not help. (Procedure: hold down reset button, then power on held down at same time, then still holding power down, press and repress reset button several times, to clear printer eprom.) but did not help, still same problem. Also, removed ink cartridges, then removed print head, cleaned and soaked print head in warm water let dry overnite, reinstalled all, still same problem..Also, corruption started likely with registry file altered, as two other printers now have same behavior/problem, wont print, flashing lite same pattern. Corrupted OS file spread to all printers. May have somehow damaged all printheads, as this is what this seven orange flashes indicates with the i550 canon printer. Reinstalled drivers several times, no help. Tried updated drivers, no help. Printer shows same error even with USB unplugged. Problem is transferred to damage within printer itself, wont undo, even with eprom reset. Printer will not respond to computer printer driver's maintanance commands. Gives status error, printer not responding, with same flashing lites pattern. Printer is as if is "locked up." Wont respond at all. Either eprom corrupted, damaged, or somehow frozen. Yet gives print head error fault. On several printers after each connected to same computer, then this error fault displays on all printers. Is spread to each printer, as if a corrupted file from computer in turn damages printer functionality, in separate printers. Yet printers wont reset, eprom is frozen, stuck, in locked up error state.-   Guest
Solution #1
posted on Apr 08, 2009
Not Rated)
yahyaa
Rank: Apprentice
Rating: 0%, 0 votes
i just had my computer updated but unfortuantley the software of the canon printer has been deleted and i canot find the cd rom to download it again please help
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a... (More)
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
my printer won't print from my computer. won't allow form me to delete items in que.
Answer
"No scan options -- refer to device documtation to troubleshoot"
Describe your Printers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Sedona, AZ
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
