When turned on programmed and started. It fills with a little bit of water the drum does not turn, it empties and displays F11 fault notice. I have f11 coming up on the programmer. Tried the Temp and Soil Type button approach but I do not get any further than that it part fills with water and then stops. It still shows Fault F11. I need more info.
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
dyson cr01 showing fault 70 600 2701 when i clear it by following the hold temp while turning on and...
(More)
dyson cr01 showing fault 70 600 2701 when i clear it by following the hold temp while turning on and pressing soil within 3 seconds i get the next fault showing f11f10f11v130
my dyson cro1 is saying not filling but there is water in the drum then the washer stops it seems to...
(More)
my dyson cro1 is saying not filling but there is water in the drum then the washer stops it seems to fill on the left side of the powder draw please help me
