Question about Acer Aspire 5920 Notebook PC
No sound on tv when laptop connected via hdmi
Having sound trouble when connectinmg my new acer laptop to my new phillips 42"lcd tv getting via hdmi getting great picture but no sound anyone help
  • meteshadow May 11, 2010
    of course you tired to check volume ?
    Problem Solver:
  • 10 Answers
If you are running windows xp or linus i may not be able to help altought the problem might be solved in almoust the same way. For windows vista right click on the volume icon in the system tray icons and choose playback devices select HDMI output ( for 5920G is "Realtek HDMI Output" ) then press the "Set Default" button. The other way around is to go in the Control Pannel in the "Hardware and sound" cthegory and select sount than seth the default output to Realtek HDMI Output in the "Control Pannel Home" view, or in Classic view click/doubble click on "Sound" icon ( a speaker ) and do the same. In windows XP there is a similar approach. In linux go to System ->> Administration ->> Soundcard Detection and you should find a setting equivalent to the one in Windows
Posted on May 29, 2009
Ok having solved the same problem on my compaq it might work for others as well when connecting to tv thru hdmi picture but no sound.bear with me I am no expert but I had same fault and everyone told me to set hdmi icon in sounds tab to default pretty hard to do when there is no icon there lol first I checked devices manager in control panel went to sounds games ect and checked to see if hdmi was supported mine was thru an intel(r) high definition audio hdmi checked and it said it was working but still no icon went to intel web site and they have a free check you can do on your pc this showed my graphics card needed up dating not the sound card thischeck will automaticaly up date it did this plugged my hdmi cable in and the icon appeared in sound tab set it to default and it worked fine apparently the graphics card has to call for a signal from the sound card in order for hdmi I'm running windows 7 but it works for vista as well hope this helps
Posted on Dec 03, 2011
    Problem Solver:
  • 7 Answers
Easy fix. Select your digital audio out in sound settings on computer, then hook up HDMI cable to TV and computer. Then restart computer (that is the trick). You should be all set. Good luck
Posted on Aug 04, 2009
Transfer sound from laptop to tv/ acer aspire 5332
If you have a HDMI connection at both ends you should be getting HDMI audio on your TV from your laptop.
Aug 12, 2012 | Acer Palmrest for Aspire 5332, 5516, 5517,...
Connecting my laptop to my sansui 42" lcd tv via the hdmi cable, i get clear picture but no sound
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
May 17, 2011 | Sansui HDLCD3200 TV
Hey iJust bought a 42 inch Phillips lcd tv And i am trying to attatch my lToshiba E100 Satllite lap top to it via the HDMI ports on both the tv and laptop but nothing is happening
When you have the tv connected and both on, Switch the TV to the HDMI feed then press the [FN] key and hold and start pressing the [F4] key counting to 10 between presses. You have to tell the computer bios to activate the external port and send video signal to that port.
Mar 14, 2011 | Computers & Internet
How do i connect my acer aspire 5000 series windows 7 to my phillips 32 lcd tv with hdmi
You should just have to plug in the pc and tv with the hdmi cable and go to the input options on the tv and select either hdmi 1 or 2.
Dec 25, 2010 | Acer Aspire 5520-5908 Notebook
Issue playing audio from AcerTravelMate6593 on Phillips37PFL7603D
You need to run the audio out to an amplifier such as a stereo unit. The computer doesn't have enough power via the line out to make the TV pick up the sound by itself unless you turn the volume all the way up and maybe not even then, so an amplifier is your answer. It work for me.
Aug 17, 2009 | Acer TravelMate 6593-6656 Notebook
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
No sound via TV when PC connected
1. Ensure the TV is set to "home" mode in the user menu. If set to "Shop" it will not retain audio settings change
2. verify that the Audio out from the PC is working. Use a set of headphones just to verify
3. Triple check that you have the audio input assigned to the correct HDMI input
4. after doing these if it still doesn't work, I would suspect the Software update had a side affect that phillips is not aware of. Since this function would probably be missed by Phillips software testers, it is highly likely that this is possible. Contact phillips and let them troubleshoot the problem with you. Let them know it happed after you did the update also and let them know that you have verified the audio out from the PC.
May 20, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Jan 19, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 5920 Notebook PC Logo
752 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
