Question about Toshiba Office Equipment & Supplies
Need to set a Toshiba e-Studio 352 to 9600 baud
I have a Toshiba e-Studio 352 with single-line fax board. I need to compensate for a bad phone line. Someone suggested I turn off JBIG compression and turn off v.34. I don't have a fax service manual and I was wondering if anyone here would be able to supply me with the proper codes.
Or, if you have a better solution, that's fine too. I can turn on "Quality Transmit" per fax and I can turn it on in the address book but I need to have it turned on by default for every fax.
flopez
  • 161 Answers
SOURCE: Any way to manually LOWER the Fax Connection Baud Rate?
Newer fax technology adjusts transmission speed automatcally, so no adjustment is necesary. therefore, there is no menu option to change it. Your problem resides either on your phone line or the one you are trying to connect to. Call the other people and ask them if thei are receiving without problem. If you are able to transmit elsewhere and the other party is receiving from everywhere, try turning off the ECM option on your unit.
Posted on Nov 01, 2007
ctf1800
  • 4402 Answers
SOURCE: sending fax
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Posted on Jan 10, 2008
  • 44 Answers
SOURCE: Need to change Baude rate of HP 4215 all-in-one mechine
That might help. Faxing is signal timing specific. I believe they are sent from the factory to run at "fast" which is 33.6kbps. Try to set it to medium first (14.4) if no luck set to Slow (9.6). Try these steps:
  1. Press Setup .
  2. Select Advanced Fax Setup .
  3. Press OK .
  4. Select Fax Speed .
  5. Press OK .
  6. Select Medium .
  7. Press OK .
Posted on Nov 13, 2008
  • 5 Answers
SOURCE: set up fax and dsl using one phone line
You can buy a splitter to put on your line so you can run both devices. They sell them at the dollar tree big lots and everywhere else usually, and range from .59 to $2. as far as another DSL filter ask a friend neighbor or co-worker if they have or had dsl and have an extra filter. If not then you can pick them up for a couple of bucks at radio shack
Posted on Feb 21, 2009
FixinFax
  • 3085 Answers
SOURCE: where do I find Baud 9600 Rate and ECM?
You can't, plus it will not help on a digital phone system. ALL fax machines are ANALOG devices.
Posted on Jun 29, 2010
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Toshiba E455 w/fax kit is not sending and receiving faxes well. Our phone vendor is saying that the baud rate is set too high on the Toshiba's and our system cannot handle it.???? Is this true?
Granted I only have 27 years in the copier/fax/printer service business but I have never heard of the fax comunication speed being set to high for a phone line to handle. If you get some or most faxes ok then I tend to suspect ECM being the cause in these cases. ECM stands for Error Correction Mode. I do not know how to tell you to check it on your machine as I am not familiar enough with the 455 but you need to check your fax settings and try turning ECM mode to OFF. It stll could be phone line related but turning off ECM will fix most of those issues.
Good Luck and Thank You for using Fixya.
Jan 01, 2011 | Toshiba e-Studio 350 Copier
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
TOSHIBA e-STUDIO232 fax settings for VoIP line
No settings, a fax machine will not work reliably on a Digital Phone Line.
Apr 12, 2010 | Toshiba e-Studio 232 Black and White...
Toshiba 2500c Fax board
No need, just the fax board in order to do faxing. But if u have printer kit, u can do network fax.
Aug 25, 2009 | Toshiba E-Studio 3511 Color Copier
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
SHARP F0-4400 Need to lower baud rate to 9600 on
Don't do it, it will make your machine extremely unreliable.
Fax machines are ANALOG devices and will not work on a DIGITAL phone line.
Jun 26, 2009 | Sharp FO-4400 Fax
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Jan 23, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba e studio 50f problem with driver software
U need to make sure the phone line is working. Hook a single line phone to the line, and hear whether tone is available, notices also is there any noise on the tone, this may affect the line condition.
Make sure u plug the phone line to the "LINE" port.
If no tone on the line, then u need to check with the telco...
Nov 21, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
312 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
