Question about Craftsman 24 Hp 48" Deck Yard Tractor
Kohler engine wont recharge on tractor
Craftsman tractor. Kohler engine. New battery. started three times on its own. now it's back to needing a jump start. why is it not recharging the battery when it's running?
  • Samuel Charles Spriggs May 11, 2010
    There is a wire (probably red) running from the magneto (flywheel area) to the ignition switch. This wire should have a fuse in it -- if it does, check that fuse and let me know what you find.
    thanks...
    Charlie
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
Either the stator went out or the voltage regulator is faulty and must be replaced
Posted on Jun 03, 2009
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
Craftsman lt2000 17hp kohler Has12volts to solenoid and only clicks and doesnt crank. Jumped to starter red cable and starts.
The battery is weak or needs a charge. Have it load tested at a parts store. It needs about 14 volts to start.
Jan 15, 2013 | Craftsman Garden
When turning ignition key to start engine the flywheel only turns 1/4 around and then stops when starting motor.
From experience I would suspect a broken decompressor lever on the camshaft. A battery fails very fast when starter comes to a dead stop a few times. Try a fully charged battery but if the problem comes straight back I'd bet on the camshaft. A car battery can usually push the engine over the excess compression.If it is the decompressor engine has to be taken apart.
Feb 01, 2012 | Craftsman 18.5 HP 42"
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
The engine wont turn over. I can see it turn slowly(as fast as a snail) and then stop. I put a new Kohler starter on it and it still turns to slow to start. What is wrong with it.
if you have a multimetter mesure the value from the ground to positiv polarity of the starter-value must by lower 30 ohm.if there is good please check mechanical coil starter contacts and the batery. try to recharge the battery .if doesn,t work propertly the last solutions it,s to change the schaft bettw. starter and engine.be sure to the moment when you press bettw. (screw) starter -engine body.
Sep 11, 2009 | Craftsman Garden
Craftsman 24 kohler engine
there is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
449 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
