Question about SmartParts (1DPFSP01) Digital Picture Frame
Digital frame won't turn on after firmware update
Smartparts model sp1100
SOURCE: I would like to know
I had the same problem with an SPX08E. It turned out that enabling the auto light sensor was the cause!
The way I fixed it was to remove all memory cards and attach the frame via USB to a PC. Then use windows explorer to delete all folders and files on the frame other than the smartpix installer MSI. Then remove the USB and power cycle the frame. It will come up at the main menu and you then have about 15 secs to navigate to the settings page, scroll down to the reset settings tab and reset all settings to defaults. You can then transfer any pictures you want back to internal memory.
Do not turn on the light sensor or you will have to do it all over again!
Posted on Dec 15, 2008
SOURCE: smartparts digital frame XPX8 won't turn on
The frame has a light sensor. If it is too dark, the frame turns off the screen. You can change the sensor setting to avoid this problem. Check out the FAQ as following http://smartpartsproducts.com/content/support/faq/news.php?newsid=16
Posted on Jun 01, 2009
  • 11 Answers
SOURCE: Frame will not power up or start.
The power adapters for the SP15MW's burn out very quickly so every thoug you have power in the outlet, it is not getting to the frame. Take the adapter to Radio Shack to have them test the voltage. If it's dead, you need to replace it and then the frame will work.
Posted on Jun 27, 2009
SOURCE: I can't delete pictures from my Smartpart Omintech photo frame.
I had the same problem. I "thought" I was deleting them via my computer (using the delete function in Windows Explorer). However, that doesn't really delete the files.
I had to manually delete 82 photos (one by one) using the klunky menu buttons on the frame. I hope it works. Note that the frame cannot be connected to your computer when you're doing this.
Posted on Dec 14, 2009
SOURCE: SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Posted on Mar 11, 2010
Delete pictures from smartparts ps-74
Do not connect to the computer. Turn the frame on. Use the remote and I can't remember how I did it, maybe SETUP, but it gave me a drop down to delete all photos and I hit enter and it did it. Hope this helps a bit.
Jan 02, 2012 | SmartParts (1DPFSP01) Digital Picture...
Wont power on
mine has the same problem... check it out in www.smartpartproducs.com (in the bottom has a firmware update).
i did it.. for my surprise the screen get red and green like the wizard says... but after the update, the picture frame still with black screen.
doesn't solve my problem... but i see that it still working... just some problem with the screen (software i believe) remains...
ryller@gmail.com
Feb 12, 2011 | SmartParts SPX8 Digital Picture Frame
Hi...my SmartParts Digital Photo Frame, Model number SP15MW, is not working right. It has pink vertical lines going through the photos and looks awful. I haven't used it much and can't figure out why its...
I had the same problem, I downloaded the desktop software from the manufacturer's website at: http://www.smartpartsproducts.com/content/support/optipix/index.php
It fixed my problem. Create a folder on your computer's desktop, remove the photos from your SD card, use your cable to connect your computer to the frame, then re-import the pictures to the frame using the optimization tool on the Smartparts Desktop. Works like a charm!
Aug 09, 2010 | SmartParts SP15MW (092566981886) Digital...
Hello. We received a SmartParts digital picture frame Model SP800W and it doesn't turn on even with the AC power cord plugged in the wall. There is no sound coming from the frame ( sounded like there was...
Probably more than it's worth! Many of these items were found to be defective when shipped. This is the 41st one of these I have heard about with the same problem.
If you can return it for a refund or swap for another brand.
Please rate my help++++Thanks for using FIXYSA
May 22, 2010 | SmartParts (1DPFSP01) Digital Picture...
SmartParts Model SPX7E has worked for several months, now the display doesn't work and just has a humming sound when I turn the power on. What's going on?
Yes, we bought 3 of these frames and NONE OF THEM DO NOT WORK! They all have a problem with the the display fading in the quality of picture. I do NOT recommend anyone buying this product.
Oct 06, 2009 | SmartParts INC. digital frame. 7.0 in....
Need replacement stand for Digital Optipix Pro Picture Frame
Since the original manufacturers do not seem able to help, you may find one on eBay
Sep 12, 2017 | Smart Parts Digital Picture Frame
Can not find the setup file for the smartparts 7 inch digital pic
The setup file is on the frame. Connect the frame to your computer w/ the USB cable. Go to MY COMPUTER. Look for your frame as a removable device and open it up. There is a blue icon called "setup." If you click on it, it will start to download to your computer. If you can't find it, you can download from Smartparts website at this link:
http://smartpartsproducts.com/content/support/optipix/optipixlogin.php
Mar 07, 2009 | SmartParts INC. digital frame. 7.0 in....
SmartParts (1DPFSP01) Digital Picture Frame Logo
107 people viewed this question
Top SmartParts Photography Experts
Tony
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
