Question about Yamaha RX-V463 Receiver
Subwoofer sounds like its going to blow up, no sound out of the rest of the speakers.
Hey guys, I have a yamaha rx-v463. I recently went downstairs to shave and shower. I left my tv and sound system on. When I got out of the shower it sounded like a bomb was going off in my room. My subwoofer was playing a horrible tone and the rest of my speakers were playing nothing. When I mute the receiver no sound. The second I take it off of the mute, for example on -79dB, my subwoofer makes that horrible sound. It sounds like my receiver is blown. help?
  • 50 Answers
Get a new reciever you idiot
Posted on Nov 23, 2009
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
I.want.to.use.a.4.ohm.sub.woofer.with.my.satelite.8.ohms.can.i.do.this ?
I'm making an assumption: that you're using a powered subwoofer as required by this receiver.
Since the RX-V463's amplifiers don't drive the sub directly, and it supplies the sub's amp with only a Line Level signal, the impedance of the sub is irrelevant.
http://www.retrevo.com/support/Yamaha-RX-V463-Receivers-manual/id/13748dj482/t/2/
Jan 11, 2011 | Yamaha RX-V463 Receiver
How do i turn on all 5 speakers for my yamaha rx-v463 receiver
To turn on all 5 speakers from your reciever you will want to press the audio selct button on either your remote or on the front of the unit itself. This will scroll through the different sound fields and the easiest thing to do is to look at the front right of the recievers display. While scrolling through you will see the speaker icons and all 5 channels should light up when your on the correct soundfield. Dolby digital 5.1 and all channel stereo are common soundfields that use all the speakers. It is important to remember that your surround speakers are only intended to reproduce sound effects, and not full range audio like the fronts. Of course, if it is your desire you can definately override this.
Hope this helped,
Thanks
Jan 03, 2011 | Yamaha RX-V463 Receiver
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
How to use sap with a rx-v463?
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
Oct 10, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
Yamaha RX V463 AV Receiver-I have an LG digital LCD tv and hooked up the two up by HDMI and an optical cable. I Only get sound from the right front and the subwoofer The Rest of the 4 speakers have no...
If you're getting audio out of one speaker, it's likely not an issue with how the TV's connected to the receiver, but an issue with how your speaker's are connected.
If you run a "speaker test", do you get audio out of all your speakers? If not, it's likely you mixed up your positive and negative connections when connecting your speakers.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Rx-v463, no sound from rear speakers, and hookups
Sounds like an internal software issue dealing with this device.you may have to return it to the manufacture for this repair.
Jan 28, 2009 | Yamaha RX-V463 Receiver
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Jan 16, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V463 Receiver Logo
382 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
