Question about Sony Playstation 3 (PS3) Console
PS3 HDMI Problem
Ok so i have this ps3 hdmi problem with my tv there seems to be some buzzing sound which cuts out my sound. the sound come back on at times but just goes of over a short time.
also the sound seems to work on a lower resolution 576p but cant on any higher resolutions. please help! thanks to anyone who does or trys.
    Problem Solver:
  • 8 Answers
It seems like the connectors on the HDMI cable is screwed or maybe a small connection issue within the console try a new cable is un helpful may need to check the connection on the machine or TV
Posted on May 29, 2009
After cutting off ps3 an then to switch back to tv there is no sound coming out .
it can happen if you have the ps3 on HDMI lead. some times the ps3 can still be sending a signal and the HDMI side of the tv is still open on sound. up date the ps3 firmware. should sort it out. if it has been updated change the HDMI lead. should sort it out.
Sep 21, 2013 | Televison & Video
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
PS3 HDMI connection issues
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 screen flash / sound cut-out
The PS3 has an issue with what's called the "HDMI handshake" between the PS3 and the TV. The PS3 does not even realise that this is happening. What you might try to do is turn the system on, play a game, and when the flashing and no sound occurs, unplug the HDMI cable from your PS3, wait a few seconds and plug it back in. This may resolve your issue. If it doesn't work, try component cables, there is no known issue with this problem occuring with this type of connection. Good luck!
Aug 20, 2009 | Video Game Consoles & Games
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
There is a slight buzzing sound on my TV
its the tv dude cuz i put the yellow white and red on a small old sony tv and it made the same noise and everything but then i changed it into another t.v. about 73 inches and it worked fine with an hdmi change the t.v.
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Sony Playstation 3 (PS3) Console Logo
198 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
