Question about Black & Decker TRO910W Toaster Oven with Convection Cooking
Position of part for TRO910W
I WOULD LIKE A SCHEMATIC FOR TRO910W toaster oven so i can put the spring back on. don't know how one of the parts is positioned.
Take the cover off by removing 6 screws around the back and 7 on the bottom (2 of these are safety screws but can be removed by a small flathead screwdriver); once you romove the wrap-around "hull" or cover you can see the spring on the left side of the oven from the frontal view.; the door stop is sort of a L shaped piece which you insert from the inside of the opening on the frame & thru the little hole on the left side of the door; once you do this stretch the spring and attach to the hole into hole you see on the middle of the L shaped piece.
Posted on Jun 07, 2009
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
The door on my toaster oven will not stay shut can I order a new spring?
sorry we are not the manufacturer or RIVAl toaster ovens . we do not know .
Jun 26, 2016 | Rival "CO602 6-Slice Toaster Oven Pizza...
Parts heating element
I received a new euro-pro ritisserie convection oven for Christmas and I just love it, but, the heat bars stopped heating. I miss it so much and don,t know what to do to fix it. Barb Tyrley
Oct 11, 2013 | Euro-Pro TO161 Toaster Oven with...
The heating elements on top do not come on to toast or bake the topside. The bottom elements heat up just fine. How do I troubleshoot? Is it worth fixing?
The following phone number will connect you with service department of Black and Decker and maybe they can tell you if it is cost effective to repair or if you should just buy a new one.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Mar 22, 2011 | Black & Decker TRO910W Toaster Oven with...
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
The spring detached causing the door to stay open
take the cover off by removing 6 screws around the back and 7 on the bottom (2 of these are safety screws but can be removed by a small flathead screwdriver); once you romove the wrap-around "hull" or cover you can see the spring on the left side of the oven from the frontal view.; the door stop is sort of a L shaped piece which you insert from the inside of the opening on the frame & thru the little hole on the left side of the door; once you do this stretch the spring and attach to the hole into hole you see on the middle of the L shaped piece.
May 29, 2009 | Black & Decker TRO910W Toaster Oven with...
Will Purchase Oven or Parts from Non-Working Oven.
Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
May 13, 2009 | Black & Decker CTO649 Toaster Oven with...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Black & Decker TRO910W Toaster Oven with Convection Cooking Logo
313 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
