Question about Fuji FinePix A360 Digital Camera
I need help..i delelted my pix in camera..but when i connected my sd card to pc..it says format..shud i format it...if format what format shud i format it
SOURCE:
SOURCE: 8GB SD card not working in Fuji Camera
switch around the 8gb memory card
i had the same problem
Posted on Aug 05, 2008
SOURCE: New memory card
Hi I have bought a new memory card, Olympus XD M 1GB. For my Fuji fine pix A330 camera, and I can't get it to initialise, or format properly, can you help me many thanks TRENA
Posted on Sep 28, 2008
SOURCE: error ox80070052 copying to sd card
I had this problem with the jump drive I am using in my digital frame. The drive has lots of open space, but not all the pictures will download on it, and i get the Ox80070052 error message.
I fixed it by re-formatting the jump drive. I moved all the files on the jump drive to a folder on my computer. Then i re-formatted the drive using a FAT 32 configuration. instead of a FAT configuration.
After the re-format, all the pictures transfer to the jump drive with ease.
Posted on Mar 30, 2009
SOURCE: camera says SD CARD NOT INITIALIZED
card not initialized
Posted on Jul 17, 2009
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Posted on Dec 22, 2009
Help me import from nikon cool pix s210 to Wlndows Live Photo Gallery 2011....laptop not recognizing camera
The best way to transfer pictures from a camera with an SD memory card is to do it outside the camera. If your computer does not have an SD card reader built in, you can buy an external USB card reader for $20 or less on E-bay, Amazon, etc. Remove the memory card from the camera and insert it in the card reader. Your computer will treat the card reader and SD card just like it treats an external hard drive. Either drag-n-drop or copy and paste your pictures from the SD card file to a file on your hard drive. If after you have copied and backed up your files you want to reformat your SD card, replace it in the camera and format it in the camera, not in the computer. SD cards formatted in a computer will often not work in your camera because of slight differences in the formatting.
Jul 19, 2014 | Nikon Coolpix S210 Digital Camera
My camera says memory full
Are you using internal memory or an SD card?
Internal is only 10mb, and if that gets full it happens real fast - the only thing you can do is get out the cable to connect to a PC and download the lot to a new file (call it Rescue, if you like).
If you are using an SD card, then pull the card, put it in an appropriate card-reader, and again download to your PC. If you don't have a card-reader, buy a new card (say 2Gb), put that in the camera and format it in camera. Put the old card in a safe place until you get a reader.
Jul 05, 2014 | Pix FUJIFILM Fine A920 Digital Camera
My micro sd memmory card has benn locked by a password by sum1 and it cannot be opened in any way so is there any solution i can open it. and i dont need any data in the memmory card. i just need it to be...
The micro sd has no lock tab to slide on the side, but the SD card adapter does. Unlock the SD card adapter, and format the micro sd card using a laptop or PC. The only way your micro sd card could be password protected is using encryption. If this is the case, formatting the card should remove the password.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 10, 2011 | Lands Phones
My Kodak C633 is not seeing/recognizing the SD card.
The reason this problem occurred is that you likely never formatted the card. The card will work fine in the beginning for the first few shots, but eventually will corrupt. But don't format that card just yet as it will erase the card.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're very inexpensive these days:
http://www.amazon.com/s/qid=1246813724/ref=sr_st?keywords=sd+card+reader&rs=172282&page=1&bbn=172282&rh=n%3A172282%2Cn%3A%21493964%2Ck%3Asd+card+reader&sort=price
AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Jul 05, 2009 | Kodak EasyShare C633 Digital Camera
Internal memory
Hi there.
Providing you have a SD memory card in the camera and the card is empty you can transfer all the data from internal memory to the SD card using the camera's menu.
Good luck and thanks for using FixYa!!
May 22, 2009 | Cameras
Cannot transfer photo from my SD card to computer
either your pc card reader or adapter for sd card is at fault here....but try this way connect your camera to pc (using usb cable)...go to my computer see the new device (camera) click on it to open ...your pix are there now copy & paste (click & drag) to your folder on the pc...hope this is helpful...feel free to rate
Apr 22, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Camera is calling for the SD card to be formatted
if this the very first time using it (sd card)...plug your camera to pc using the usb wire it came with...you are setting it up so that you can put pix/video on it.......now if you have pix video files already on it (formatting will totally erase it)....if you really dont need/want/nor care for the pix just follow the same info from the top............
Jan 19, 2009 | Kodak EasyShare CX7330 Digital Camera
Nikon coolpix L18. Can't put pix on comp. format card
I suggest you to remove the card from the camera and use a memory card reader to transfer the pictures to the computer. Note that the memory card should be formatted in the camera. Once the pictures are transferred you can reinsert the memory card to the camera and then format it in the camera.
Jan 15, 2009 | Nikon COOLPIX L18 Digital Camera
Help!?
maybe if you reset the cam and card, by formatting it using the PC rather than the Camera, save what pix u can then format, to format, goto my computer right click camera drive, usually F:\ press format, do a full format, dissconnect from PC then make sure u leave power on and format thru the camera, dont know if its possible top save pix but this shud fix the whole card issue
Jul 27, 2007 | Vivitar ViviCam 5100 Digital Camera
Vivicam 5100 card error
ok this is a common problem, all you need to do is connect the cam to the computer, on the cam press disk drive, then in my computer find drive, usually F:\ right click press format, make sure after you format, dissconnect the cam from the PC. Leave the camera POWERED ON then through the camera options press menu setup and format then execute, then cam shud be fine, btw doing this will erase any pix you have on there at this moment in time
May 03, 2007 | Vivitar ViviCam 5100 Digital Camera
Fuji FinePix A360 Digital Camera Logo
16 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
