Question about JVC Car Audio & Video
Room for speakers
Not much room to play with need more and better sound in mr2 but its obviously got to be right before i start chopping
  • 655 Answers
Hello jarvis40,
You did not say exactly what improvements you want to make, what your budget is, nor if you are looking for a stealth install.
First I'd recommend that you look at what some other owners have done and see what you like. The MR2 Owners Club Forum would be one place to start. Many times you will find unbiased reviews of specific gear. There are installs documented with photos, and detailed step-by-step procedures. Generic car audio forums are also good. For comparing equipment and pricing, you simply cannot beat Crutchfield. The prices at Crutchfield are generally lower than you will find at your local audio dealer, but somewhat higher than other online stores. But they are excellent for doing research and if you do buy from them, you will find that the extra dollars paid buys you the absolute best service available.
If you're looking just to add an amp and a sub or two, and want a custom look instead of a "big ugly box", you might want to check out Concept Enclosures. He constructs custom boxes to fit specific places. Sort of like the JL Audio stealth box, or MTX Thunderforms, but less expensive. He has a design for the MR2.
And if you just want to change out your factory speakers, while you are browsing the Crutchfield site, check out the Focal speakers. The Utopia Be NO. 7 is simply the best 6.5 " 3-way component automotive speaker system in the world period. But if your budget won't stretch for the Focal's, consider the Alpine SPS-600C component system. They sound amazing.
Hope this helps.
Posted on May 30, 2009
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
I have a 91 MR2. Everything was working fine and simultaneously the condenser fans are running constantly, the power steering is not working, all power was lost to the electric windows and the AC system...
look in teh power distribution box under the bonnet near the battery sounds like the fault is here but what?? broken wire contact?? who knows without a play
Dec 23, 2010 | 1991 Toyota MR2
I have no sound at all coming from the speakersom ym scaleo 600 computor
what did you check???
start with the obvious:
1. are the speakers plugged in and turned on?
2. are the speakers plugged into the computer?
3. can you get sound by plugging in headphones to the headphone jack or speaker out jack?
4. it your audio un-muted for all the functions?
5. is the audio application properly configured?
6. will it play a known good file like the windows media files?
7. Does it play the windows startup or shutdown files?
When you get a NO! you will be in a better position to get an ANSWER.
May 16, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
My Kenwood KRFv5300D is working throught the tuner / radio channel but wont play sound from the TV - I have a digitial cable running from the amp to the TV but nothing else - should i have more cords then...
The only way it cCOULD work would be from a Digital Audio Output to a Digital Audio Input.
What is the model of the TV? Does it REALLY output a digital multichannel audio program? TV's aren't generally known for their audio chops and some of us own monitors with NO speakers or sound capabilities. Hence we buy things like Kenwood receivers and better speakers.
I would recommend that you draw the TV-related audio from the same place the TV gets it - Cable / DVD / BD. The audio hookup is simpler and the fewer intervening connnections, the better.
Apr 22, 2010 | Audio Players & Recorders
I have a 2008 Hyundai Tucson with the premium sound package. The first radio was replaced by the dealer as the radio has no bass at all. The treble even turned to the lowest setting pierces my ears. The...
Try replacing the factory speakers with a better quality speaker. make sure you listen in a sound room before you have them installed. make sure you like the sound of the new speakers before installation. also have the radio tech listen to your car to make sure radio is ok
Feb 12, 2010 | Car Audio & Video
Why put woofer on the floor?
Because low frequency sound travels better lower to the ground. The effect if placed high up would be minimal
LF sound has more punch that regular speaker sound, it also caused more speaker movement and if placed high up could in theory pull itself from the shelf or mount.
You tube has some sub sound tests you could use to show this theory. or maybe the candle trick of putting a lighted candle in front of a sub when turned up a bit may convince you.
put a candle about 6 inch away from a sub and play some nice bass it will blow out the candle more than a regular speaker
Oct 11, 2009 | Insignia Audio Players & Recorders
Add 2 speakers outside on a 6 speaker surround sound and hear all
You won`t get surround sound mix with 2 speakers, you can have a 2nd zone but this will only play a "Stereo Sound" if you have that playback option with the SC-RT50, what you will need is a speaker selector switch or better known as an A & B switch, this will ideally run from the front left and right speaker output of the receiver into the A & B switch then run into each pair of speakers inside or outside, what is common nowdays are receiver that are known as 2nd zone connections where you can have 2 sets of speaker in different rooms, unfortunatly the SC-PT50 does not have this option.
Feb 03, 2009 | Panasonic SC-RT50 System
Pioneer pl 200 , no sound well real quiet
The third wire is a ground wire I think. You are running the ttb through a phono input and not through a line level input on your system right?
Nov 14, 2008 | Technics SL-1210 Turntable
Sound - music
use axtranal soeakers and creative make s ax fi for labtops nice card
Jan 28, 2008 | Acer Aspire 3680 Laptop
Pc audio
Happy holidays Js3131
well friend, you got here a corrupted pagefile, problem with DX9, (have to reinstall it) and may be, sound card failing problem with drivers. ( reinstall drivers sometimes fix this) .
finally you can Defrag your drive, to see if this disipate the problem.
any other,...drop me a note
Dec 17, 2007 | Audio Players & Recorders
Car Audio & Video Logo
80 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
