You have to be the computers administrator to change any values on any
hard drive on your computer.
Click
start control panel user accounts on the users tab click the name of the
computer administrator you must have full control
Click
start click to open on my computer you should see your usb drive could be E: or
something right click select properties there will be an array of options
select
the sharing tab option then advanced sharing make sure you have a tick in the
share this folder box
then
click permissions make sure you have all 3 boxes ticked full control changes
and read
in windows 7
Click
start control panel user accounts click on the administrators account if you
have made one or you will have to create one in windows XP
The Fat32 (FAT) format is used to format disk
drives on Windows-based computers and can also be recognized by the Mac's OS X
operating system.
You can format a flash drive with the FAT format so that it
can be used on both PCs and Macs. The procedure is straightforward, if
different depending upon the operating system being used to do the formatting.
You do not need to purchase any additional software to
format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory
http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html
Format USB flash drives with
FAT, FAT32, or NTFS partition types.
Plug the Flash drive into a USB port on the Mac.
Double-click the "Applications" folder inside of
the Mac's hard drive. Scroll down to the "Utilities" folder.
Double-click the "Utilities" folder.
Scroll down to the Disk Utility program.
Double-click on the Disk Utility program to launch it.
Click once on the icon of the Flash drive that is in the
left column of the Disk Utility program's main screen.
Click on the "Erase" tab at the top of the window
Name the Flash drive in the "Name" column at the
center of the Disk Utility program's main screen. Select "MSDOS (FAT) from
the "Format" menu beneath "Name."
Click the "Erase" button at the lower right corner
Click the "Erase" button in the pop-up confirmation
window that appears.
Wait as a progress bar at the bottom of the Disk Utility
program's main screen fills in from left to right.
Click the "Eject" button at the top of the Disk
Utility program's main screen once the progress bar is completely filled in.
Quit the Disk Utility program.
Remove the Flash drive from the USB port of the Mac.
Format Flash Drive in FAT on a PC
Plug the Flash drive into a USB port on the PC. Go to
"start," "My Computer."
Right-click on the icon of the Flash drive in the center
column of the window that appears below "Devices with Removable
Storage."
Select "Format" from the pop-up menu.
Select "FAT32" from the "File System"
drop-down menu in the window that appears.
Click the "Start" button at the bottom of the window.
Click the "OK" button in the confirmation pop-up
Wait as a progress bar fills in from left to right at the
bottom of the window where you had selected "Fat32." Click the
"OK" button on the "Format Complete" pop-up window when it appears.
Right-click on the icon of the Flash drive that is on the
desktop.
Select "Erase" from the pop-up menu.
Remove the Flash drive from the USB port of the PC.
my younger brother plugged my megf20 gigabeat to pc and he formatted that using windows xp format disk utility now when i am turning on the gigabeat i just see an error and that is
no system found on hdd
error number is 00100060
if you can help me please
i marke le 00100060 no systeme found on hdd
how do i get the toshiba firmware to start working
my son formatted my mp3 player through windows xp and now i am getting a error message how can i fix it
I have a gigabeat f20 series. I get the error message 00100060 everytime I turn the power on. Any ideas what I need to do to get it to work again?
error 00100060
