Question about Ricoh Aficio 450 Copier
Functional problem with the copier (Savin 2545) Service Code SC 546
  • ayemgap Jun 03, 2009
    Thank you. Procedure you just described is the same one posted at Fixya for another service code number. But it worked. I tried it. Thanks again!
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
  • 31 Answers
Your thermistors need to be replaced, resetting this code isn't something to play with. Fluctuations in the heating system are causing it. I've seen fuser units in this model overheat, things do melt.
Posted on Jun 19, 2009
Show duplex mod
Posted on Jul 23, 2009
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
Functional problem sc546
sc 546 is a fusing related code. either the fusing lamp or the thermostat is blown out. one of them needs replacing
Oct 01, 2010 | Ricoh Aficio 150 Copier
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Functional problem code displays sc546
sc 546 fuser temp changes more than 20 degrees after warm up. clean thermistor if tat dosent work check fuser connector. reset= enter service mode turn copier off wait 5secs then on.
Dec 01, 2009 | Savin Office Equipment & Supplies
Error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
Jul 01, 2009 | Ricoh Aficio 450 Copier
I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Jun 02, 2009 | Ricoh Aficio 450 Copier
Error Code 546 in Savin 3540 copier
enter sp mode with the following combination
yellow key then 1 0 7 and hold down stop till the screen changes go to copy sp then scroll down to 7 datalog and down to 897 sc jam reset and execute the turn off the machine and back on
Dec 27, 2008 | Office Equipment & Supplies
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
1,031 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
