I WAS JUST GIVEN A SAMSUNG HC-P4741W ABOUT 4YRS OLD, CONECTED SET TO MY COMCAST CABLE TURNED SET ON NO SOUND BLUE SCREEN WITH SLIGHTLY TURNED LETTERS STATING NO SIGNAL.TRIED ORTHER CHANNELS SAME RESULTS.WOULD LIKE SOME INSIGHT WHAT PROBLEM IS AND COST TO SEE IF ITS WORTH GETING FIXED
  • veg566 May 29, 2009
    I HAVE NO CABLE BOX, CABLE GOS DIRECTLY TO TV. I HAVE A TV ALREADY HOOKED UP TO CABLE , TV WORKS FINE
    Brigadier General:
  • 3,614 Answers
better check first the wire connections from your cable box to your tv, it seems that your tv was not gettin any signal from the box or the box itself has the problem. better to call your cable provider regarding on this.
Posted on May 29, 2009
  • micromaster
    micromaster May 29, 2009
    try resetting the unit setting
When i turned on my Samsung LED television all i get is a blank grey screen with no sound. i have Comcast but my other tvs are fine. i can play a dvd on it with sound and screen, no problem and the menu...
Follow the cable from the Comcast set top box and see where it is plugged into the tv. Check what that jack is labled and then select that option on the TV menu. My guess is that the tv and dvd are not both on component 2, if the are then the set top box is not connected directly to the tv but to the DVD unit. In that case, if the cable set top box is connected to the dvd, then you might need to put the tv on ch 3 (or maybe 2 or 4) or you may need to switch a setting on the DVD box or remote that selects the TV/DVD option.
Dec 05, 2013 | Samsung Televison & Video
My 2004 samsung self focus bbe digital tv had a normal picture, but recently the screen started producing yellow images. Everything we watch is in yellow tint. The model number is HC-P4741W. If anyone can...
Check and make sure that you still have your red component cable hooked up and it is tight on both ends of cable. If cable is tight, try another cable to make sure the one you are using isn't bad. If you still have a yellow picture, stick your head in the unit and see if the red tube is lit. If it is not, you found your problem.
Jun 20, 2012 | Samsung HC-P4741W 47" Rear Projection...
DO SAMSUNG HC-P4741W TVS HAVE A TROUBLE CODE LIGHT?
if color is skewed or looks 3d its a convergence problem--select that in main menu and try to adjust--if will not adjust it needs the chips for that replaced.
Jun 07, 2012 | Samsung HC-P4741W 47" Rear Projection...
Samsung HC-P4741W has no picture and no sound
Doubt it is the convergence board. It is in shutdown mode caused by an overcurrent or overvoltage condition. It will take some troubleshooting to pinpoint the part(s) that are defective. Could also be a cracked solder joint.
Jul 06, 2009 | Samsung HC-P4741W 47" Rear Projection...
Greenish haze on my Samsung HC P4741W
If you purchased it new then this clearly should not happen - if it is second hand and therefore older then the red tube could be burnt out. The convergance may simply require allignment if the set has been knocked about trying to get it to its final resting place - this would need a tech on site to set it up.
Feb 14, 2009 | Samsung HC-P4741W 47" Rear Projection...
Colours serparated, not converged, screen looks concave
Replace Both fo your STKs convergence ICs STK392-040s. For Parts Call 1-800-223-3205
Dec 30, 2008 | Samsung HC-P4741W 47" Rear Projection...
Samsung hc-p4741w flashing red light
That sound is made by the power supply who's gooing in protection mode due to some overcurent in secondary. Could be many reasons: conv. amp. IC's, video amp.IC's etc. In my opinion more then 70% chances to be the STK for convergence. Need to be troubleshooted by a tech.
Dec 07, 2007 | Samsung HC-P4741W 47" Rear Projection...
Limited channel selection
Select cable in menu instead of Ant. and reprogram channels.
Sep 23, 2007 | Samsung HC-P4741W 47" Rear Projection...
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
