Question about Car Audio & Video
Dark screen on my headrest tv
I have 2 headrest tv boss audio hp8pak and one works perfect but the other one got to dark i adjusted the brightness all the way up and tried to reset but coudnt find the reset. it was working perfectly but now its dark and when i change the color mode it works for a sec then turns to dark again
  • 20 Answers
Its defective, need to be repaired or replaced
Posted on Jun 23, 2009
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Fading brightness of sharp 20v-l70m
pls. try adjusting screen control.
Jul 04, 2013 | Sharp 25R-S100 25" TV
Tv back lite not working
Thats usually caused by the inverter especialy if the audio works perfectly. Often if you shine a bright flashlight into the screen you will see dark movement indicating the picture is working but its only a backlight issue. The Backlights hardly ever fail its almost always the inverter board. You can get the inverter boards from www.tvcircuitboards.com
Jan 01, 2013 | Televison & Video
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
1) I own a Quasar TV model# SP 3232A. I have a dark screen but good sound.What are the possible troubles. 2)Is a service manual available for this model
If the screen is dark, then the brightness and contrast adjustment must be poor. Use the MENU key (in the TV or the Remote, either) adjust the brightness and contrast as per your viewing convenience. Service manual for this model is not in my knowledge and you should not try to repair or troubleshoot it by yourself without proper knowledge of the circuit workings inside.
Jan 23, 2009 | Quasar SP-3233 TV
Dark picture
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Nov 23, 2007 | JVC AV-27S33 27" TV
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
