Question about Philips 60P8341 60" Rear Projection Television
Philips HD/TV rainbows the picture at the bottom of set.
Picture will rainbow and double vision..
I can turn the set off wait a few seconds and turn on...it then will be a good picture...and then the picture sometimes will rainbow again or be fine...
  • kroberts915 May 29, 2009
    Im located in flagstaff, az...
    is the conv circuit an easy item to get a hold of???
    Im a sign guy w/ electrical backgound...
    is this a simple swap out or solder fix???
    How would I go about finding a manual...
    Thx Again VT for the quick response...
    Scholar:
  • 150 Answers
Hi, the convergence circuit is getting ready to fail, fix it NOW and you may get away with just resoldering the STK`s, soon they will overheat and short then it`s going to be 250-300 to fix it depending on your area rates, gl, video-tek
Posted on May 29, 2009
  • video-tek
    video-tek May 31, 2009
    just a matter of removing old solder and re-soldering the pins of the 2 IC`s right now, they may fail after you resolder it`s hard to say from here :) all you can do is resolder them and run the set, if they fail again you`ll have to replace them. be SURE you buy original IC`s the subs/generics won`t hold up, ACME in orlando is where I get mine. 1-800-575-9833, gl, if you have more questions ask, video-tek
I have a Dynex 32 LCD that I can only see the top half of the picture, the bottom half/40% looks like rainbow lines. What are the possible problems and how do I fix it.
Unfortunately what you have is a fried screen. Toss it at the city dump and get a new TV. Wallmart has 36 and 45 inch TV's for under 300 dollars
Good luck
Nov 29, 2014 | Dynex DX-LCD32-09 LCD TV
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
Has a double picture and looks rainbow
A double pcture with two different colours??? more seriousely the rainbow effect could be of an appature grill un hooked in one of the three tubes (THIS IS DANGEROUS IT COULD IMPLODE) you should have a proffessional looke at it and you should NOT USE OR MOVE the TV until then.
Jan 04, 2011 | Sony KP-53V75 53" Rear Projection...
Double screen and rainbow like colors
my media player does not play occur eror in error show capture video failed, show no sound device or show input is failed
Feb 27, 2010 | RCA Televison & Video
Rainbow on bottom of picture .it is blue in color.
Most likely to be caused by a strong magnetic field. Move any/all stereo speakers, subwoofer, AC power adaptor, or other magnetic radiating object away from the TV. Sometimes the magnetic source will leave some residual magnetism in the metal parts of the TV, but that will clear if the TV is turned off and allowed to cool before turning back on.
Nov 28, 2009 | Philips 27PT543S 27" TV
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
25TS56C22125
The description of the problem points to the picture tube being bad because of the rainbow colors,as far as the white lines you might have an open resistor in the crt board,a qualified technician should take care of the problem if the set is repairable and He will know as soon as he sees it.Good luck.
Sep 17, 2006 | Philips Magnavox 27MS343S 27" TV
Philips 60P8341 60" Rear Projection Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
