Question about Amana 24 in. DWA33A Built-in Dishwasher
No problem, just looking for gal. per minute flow rate
I'm trying to size a new tankless water heater,so I'm wanting to determine my dishwashers flow rate per minute as part of my calcs. for sizing my new heater.
  • 864 Answers
It uses 1.2 gallons for each wash or rinse action in a cycle.  The water only runs until the 1.2 gallons amount is reached and then that water recycles through the pump for the duration of the action.  Start the dishwasher and time how long it takes until the water stops filling (not the entire time of the action).  Divide 1.2 by the number of minutes including seconds as a decimal fraction (i.e. 1 minute and 30 seconds = 1.5 minutes) to get the flow rate in gallons per minute (GPM).
Posted on May 29, 2009
HE error code on samsung dishwasher?
This is usually a failed HEATING ELEMENT or HEATER RELAY. Disconnect power & remove the dishwasher from under the counter.
The HEATER RELAY is located on the right side of the D/W. A metal panel/shield (on the right side) must be removed to gain access for testing.
Testing the HEATING ELEMENT *can* be done from the bottom/front---but is easier if the D/W is placed on it's back---and removing the bottom cover/panel.
In many cases I have seen failed HEATING ELEMENTS or RELAYS on Samsung D/Ws---in homes which had an INSTANT WATER HEATER (AKA: Tankless Water Heater).
This type of Water Heater requires a minimum GALLON-PER-MINUTE of water flow---before it will *heat* the water.
Many dishwashers have a lower GPM flow rate than required---this results in NO HOT WATER at all during water fill.
The D/W heating sytem remains "on" for long periods of time---each time the D/W is used.
Eventually the HEATING ELEMENT or HEATER RELAY fails
Nov 20, 2016 | Samsung Dishwashers
Installed a tankless gas hot water heater a few months ago, and ever since then when ever I turn on the hotwater, I get pockets of air coming out of the faucet. There are no leaks in the water lines, but...
1) Never, ever install tankless water heater, unless your wallet is 2" thick and you enjoy nuisance problems and recommended continual maintenance.
2) Add in-line air vent.
http://waterheatertimer.org/images/Air-vent-added-to-return-22.jpg
3) Look for check valve along the line. Look for mixing valve, pressure regulating valve, etc.
4) If you have recirculation system, remove cross-over check valve and see if problem is located there.
5) Contact Rheem. 800-432-8373 They will want model number, serial number, and name of installer. And might recommend contacting installer or plumber.
6) Increase water flow. Check water flow requirement of tankless (.5 gallons per minute activation) with actual flow at faucet.
7) Clean water filter at tankless unit.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
8) Crossover at single-handled faucet.
http://waterheatertimer.org/Crossover.html
9) Fix all leaking faucets indoor and outdoor so no air is being sucked in.
10) Bad TP valve on water heater sucking in air each time water pressure pulls on the valve?
Additional resources: No information about air-in-line
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
I have an AE125 - had it for a couple of years at the cottage. We got the water hooked up this spring and all was fine. Last weekend, the unit stopped working. I flipped the breakers a couple of times...
Can tankless electric water heater be repaired? Sure.
Is it worth the expense if problem is going to happen again? I can't answer, but can offer resources.
New tank-type electric water heater costs $207 and new tank-type gas costs $320 at local box store.
You can install new tank-type electric yourself in a couple hours. DIY repair on tankless is not easy since parts are not at local box store, and what part do you need, and tankless parts can easily cost more than new tank-type water heater.
Open following link for Bosch troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
GENERALLY, Tankless require .4 gpm (gallons per minute) water flow to activate heating cycle, and then require .25 gmp flow to keep heating cycle going.
For example .4 gallon per minute means faucet can fill 1 gallon container in 2-1/2 minutes
Some tankless units require more water flow, for example .75 gpm
Tankless water heaters have flow sensor that tells computer chip when enough water is flowing to activate heating cycle.
If the sensor is clogged, or if water filter inside tankless unit become clogged with dirt or sediment from hard water, then the unit does not signal enough water flow and will not activate.
Home filtration system and water softener can also slow the flow of water.
Low water pressure and crossover problem on single-handled faucet and crossover on recirculation system check valve and high thermostat setting can also cause heat cycle to not activate.
Tankless cannot be exposed to water with more than 11 grains hardness or parts inside tankless will coat with sediment and not work. Within 2 years the unit will not work, with diminished efficiency from the beginning.
http://waterheatertimer.org/Battelle_Final_Report.pdf
If water is hard, and you cannot soften the water, or if water is dirty and cannot be cleaned, then the best recommendation is to use tank-type heater instead of tankless.
All costs are energy. For average home: Tankless electric is NOT cheaper to operate than tank-type electric. Tankless gas saves $1-8 per month. However, cost of unit and installation, cost of potential repairs and cost of parts, difficulty of DIY repairs, required yearly-monthly maintenance, etc outweigh expected savings.
http://www.pmengineer.com/Articles/Cover_Story/8cf9e86f7c298010VgnVCM100000f932a8c0____
Upvote the help.
May 31, 2011 | Bosch AE125 PowerStar 4 GPM Indoor...
Is a Bosch Water Wizard 600 compatible with a high efficiency showerhead?
It will probably work if tankless is not older, and if water is very clean with less than 11 grains hardness, or you have frequently-maintained softener with also frequently-maintained particulate filter.
As a general rule, tankless require 1/2-2/3 gal per minute water flow to activate heater, and slightly less flow to keep heater going.
Your manual should have specific figures, because water-flow rate is definitely mentioned in troubleshoot section of every tankless manual, in every brand.
To download manual, open following link, and then select product that matches yours. I dont see a 600 series listed.
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Next step would be to check the water-flow rate on shower head.
The problem with tankless flow rates is they are rated for new product only.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Feb 27, 2011 | Bosch Water Heaters
Will the Grundfos RCP-96 model work with my Rinnai tankless heater model # C85e-1?
Grundfos RCP-96 has Flow range: 0 - 27.5 U.S. GPM
According to Amazon spec sheet:
http://www.amazon.com/Grundfos-RCP-96-UP515-55SFC-Recirculator-Timer/dp/B00128BJAO
Most tankless require .4 GPM to start burner and .25 GPM to maintain burner
Rinnai does not show C85e-1 so you will have to consult your manual to see minimum water flow requirement.
http://www.rinnai.us/tankless-water-heater/
Sample manual from Rainnai mentions 'minimum flow rate' several times but doesn't give specific number. Yet promotion blurb on page 1 says "Ultra operates at a lower minimum flow rate."
http://www.rinnai.us/documentation/downloads/U290-665x0200_Condensing_Manual_EN_FR_1-2010.pdf
Another rinnai manual mentions flow rate several times in troubleshoot section yet fails to define what that rate is:
http://www.rinnai.us/documentation/downloads/U287-1833_VB_Series_R75LSi_R94LSi_R98LSi_Manual_EN_FR_EN_FR.pdf
It might seem that tankless promoters are CTA by failing to mention specific flow rate numbers.
I think tankless promotion is a definite overachiever, and vague flow rate is one tiny example.
It proves the necessity of reading whole manual and asking questions before buying a tankless.
There's another factor to consider:
All performance numbers are based on new products in ideal circumstance, and not based on a 4 year old product located in your home.
Your flow rate may vary, especially over time, and especially if water in your area is not crystal clear, and you are not diligent with correct water softener and filter.
Many factors can affect flow rates: water pressure, number of elbows, clogs in the line, sediment, size of pipe, aireators, water-saving shower heads, local water conservation policies, water well pressure, MUD district pressure issues, your home located near end of a water main, etc.
Read tankless efficiency vrs water softener
Image of tankless parts vrs tank parts
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Bradford White tankless vrs tank side by side
Lime scale does not flush out of tankless
Tankless must have water conditions with less than 11 grains hardness
"Savings falls far short of a payback," 'without comparing service costs'
geno_3245_197.jpg Sediment clogs tankless pressure sensor without softener.
Dec 28, 2010 | Grundfos RCP-96 Recirculation Pump for...
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Water Temperature Fluctuates
no the tub faucet is the only faucet that is wide open you might have to not run full blast on the faucet , your tankless water heater is under sized for the application, to many gallons per min going thru the unit, look at the rating chart for your unit, the r94 is only 9.4 gallons per min, and a tub faucet can be upto 5 gallons per min, depending on the faucet,,
Jan 16, 2009 | RTO American Heat Tankless Electric Water...
Amana 24 in. DWA33A Built-in Dishwasher Logo
1,106 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
