Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
No water running through cycle once filled....making humming noise once clicks into cycle
Have a whirlpool gold Quiet Partner IV and when turned on today, they water fills as it should when turn on cycle and then once water is filled to where should be, you hear the relay make clicking noise. Normally, that is when we hear the water begin to move around and begin washing them. However, now, it makes that click sound and then just makes humming noise and no water is moving. I have tried to cancel and the water comes out as it should draining. I tried to restart and did the same thing agian...I let it go for a bit longer this time and could smell a burning smell, so pushed cancel again. Any suggestions of what to do or look at???? Thanks A MILLION!!!! I have the same problem as described above, minus the buring smell. I tried running it on a different cycle (pots and pans, crystal, quick wash) and when it got to the rinse cycle during quick wash it made a grinding noise like the bearings may be going bad in the motor. Is this possible?
  • 864 Answers
Both problems sound like motor has failed or is failing.
Posted on May 29, 2009
5 Suggested Answers
  • 38 Answers
SOURCE: dishwasher runs very loud
Could be something as simple as something caught in the food disposer blades. Remove the lower spray arm and filter assembly. There is a cover inside the sump that is removed and once you remove it, you will have access to the food disposer blades and pump impeller.
Posted on Feb 25, 2009
  • 171 Answers
SOURCE: whirlpool gold quiet partner iv will not turn on
Hi chrslndsy,
I'm Harvey the Master Plumber.
Your problem is: whirlpool gold quiet partner iv will not turn on there is no sign of life in it at all.
Usually this indicates that the power is disrupted. First check the breakers. 9 times out of 10 it's a broken, loose or burnt connection in the d/w junction box. It's located underneth the d/w behind the kick plate on the right or center, depending on model. Turn the power off at breaker and remove cover. Take each wire nut off and repair/replce as nessessary. Test before you close it up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 13, 2008
  • 572 Answers
SOURCE: I have a Whirlpool Gold Quiet Partner IV Model #
check the choper assembly
Posted on Feb 08, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have a Whirlpool Gold Dishwasher Quiet Partner
Hello & Welcome to FixYa
Press and hold the AIR DRY/RINSE ONLY button to reset the control, if you have already tried this and it is possible that the door was opened while in cycle then the first thing that should be checked is the door switch/lock assembly. You can take a hair dryer and try to blow air on that, if the problem returns then replacing the door switch/lock assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Dec 11, 2010
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Wet dishes
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
Dec 10, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
903 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
