FixYa.com
Tags:
RCA F25432 25
RCA TV model F25432, Ch. CTC203AD5, dead
By Duke - usenet poster
I have two similar RCA's in the shop right now for repair. There is
this one which as I wrote is dead. and there is another, a F25441 ,
Ch. CTC203AF9 which only needs the RF connector reattached to the
tuner. The two chassis are somewhat different but it looks  like until
the output section the power supplies look the same. So I took several
comparative ohm meter readings around the HV and power supply areas.
There is nothing blatantly different. The good sets supply squeals
when its plugged in but the bad one does not, which seems to suggest a
power supply problem but as I said all measuremens on the same
sections in each set corresspond. I realise of course that none of
this is conclusive but not having a schematic I was hoping to get a
break. Does anyone have any hints on this one or a method to point me
in the right direction? Thanks, Lenny Stein, Barlen Electronics.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Pasty
Pasty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Sun, 6 Jul 2003 09:48:47 -0400, "Arthur Jernberg"
This is true, and have you kept info on how often have to do this?
CTC203 win the most for that dreadful glue on that coil because the
fracture is in solder-coil wire bond itself and very tiny, easy to
miss. Coil leg that had bad solder was swimming in that glue, while
other leg is clean.  Very interimittent that could drive tech nuts,
glue will break that resoldered leg if they aren't aware of this glue
problem.
I had similar problem in CTC185 the L4401 solder was cracked, that was
only one out of many 185's.  I also keep a watch on any RCA chassis
for horizontal driver transformers that sweated all it's wax out, just
replace it because this is a sign that transformer was overheating and
blowing HOT.  These things not often.
BTW, ATC113 used exactly same SMPS & horizontal driver circuit but
good of RCA, quit using glue on that coil.  Also how often do you see
this in 32" and 36" based CTC203 chassis?  None because it has no glue
on that 4uH coil because leads is very stiff.  Rest of 27" and smaller
has 6.8uH coil swimming in glue to hold that coil in place because of
wire is so SOFT like cooked spagehetti (YUM!).
Cheers,
Wizard
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
CTC203 squealer means shorted HOT or shorts on the outputs of SMPS.
I implore all to replace just that HOT and remove that L14401 and
strip glue and reinstall coil.
CTC203's flyback in 19, 20", 25" and 27" is rarely bad, once in awhile
found bad in 32" and 36".
This quote is all is required to repair nearly 95% of this blown up
SMPS.  This is what RCA requires for rebuilding blown up CTC203 SMPS
and I add: before powering that repaired SMPS, check everything else
to prevent another "explosion" which is extremely rare outside of
these four parts.  Sometimes a fuse also depending on how that Q14101
shorted.
I have been rebuilding these about 40 times and none blew up during
repair.  Only time they blew up again was one of repeat where glue
wasn't removed while back.  Many times HOT blew that SMPS off because
of that L14401's glue.
Q14101 must be exact replacement, the other two small transistors can
be subbed by exact specs.
BTW, if anybody resolder those L14401 without removing that inductor
coil and clean off glue completely (ditto to unclogging glue from that
solder hole) will have a repeat few months to a year later.  Happened
to me twice, now I always strip off that offending glue.   We keep the
records of all units on computer, this is how I know their
backgrounds.
Had studied in that CTC203 training manual and this is exactly what I
have done for these high rate success SMPS rebuilds.
Cheers,
Wizard
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
BTW The l14401 problem is not specific to the CTC-203, a lot of the newer
Thompson chassis use a very similar circuit in the horiz drive area and
experience similar problems. FYI follow the same procedure on all RCA/GE
chassis to lessen the probability of having these bite you.
Solution #4
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Thank you to everyone who responded. I will look into all things
mentioned. Lenny Stein, Barlen Electronics.
Solution #5
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Lenny look here at this information....
This was posted a while ago by some Tech..
RCA   F31317YX53
Dead , F14201 = 5 Amp Blown. Customer Said There Were Sparks Inside Tv  .
Slidewire Electronics
Resolder L14401 . Replaced Q14401 H.O.T. #237470 .
Replaced Smoked Parts In Ps. Q14101  = #244223 , Q14102 = #147665 ,
Q14103 = #232218 , R14107 = 43 Ohm 1/4 W , R14109 = 750 Ohm 1/4 W .
Chassis Ctc203ad5  , Sam'S 4600 .
RCA   P46810LV
Dead. Wont Power Up
Chambers Electronic Service
Replaced Defective Mosfet Q14101 (237469). Replaced Burned Resistor R14125
(241258) 36 Ohm 1/4 Watt. Replaced Defective Low Voltage Regulator U14101
(237476). Replaced Shorted Smd 3v Zener Diode  Cr14108 (238099). Set Powered
Up And Worked Fine
RCA   CTC203
Dead
Replace Q14101 P/N 244223, & Q14103 P/N 232218 Both Should Be Done Together
RCA   CTC203
Dead
Sam Oyler : Electric Medic
Replace  Q14101,Q14102,Q14103,R14107 & 5 A Gma Fuse
RCA   CTC203
Dead Shorts Regulator At Plug In
Bryn Mawr Tv
Cr14109 Shorted  (243626) Causing Q14101 (244223) To Fail When Plugged
RCA   CTC203
Dead. Blows New Q14101
Consumer Service
R14107  43 Ohm Off Gate Of Q14101 Open
Q14101 # 244223
RCA   CTC203
Dead. Fuse Blown
Dash2666
F14201 Main 5 Amp Fuse, Q14101 P/N 244223, R14107 43 Ohm, Q14401 2sd2578,
R14103 1 Megohm, Q14102 Mps8599=Nte159. Resolder L14401, Connects H. Drive
To H.O.T. Base
RCA   CTC203
Dead. Squealing Noise When Plugged In
Bryn Mawr Tv
Shorted Q14401 # 242224 (2sd2578)  Q14101 # 244223
Open R14107 # 244214 (43 Ohm 1/4 Watt)
Give Main Cba Good Solder Up Many Poor Solder Connections
RCA   CTC203
High Voltage No Go.  Hums. Remove L14401 And Clean Leads To Prevent Repeat
Hot Failure
Q14101 Regulator (244223), Hot (242224), R14107 (43 Ohm),Q14102 (Mps8599)
RCA   CTC203AD5
Dead
Bryn Mawr Tv
Q14101 (244223)  Q14102 (147665)  Q14103 (232218) R14107 (244214)
Q14401 (242224)  F14210 (175425/Gma5)
Resolder L14401 Base Of Horiz Output
RCA   CTC203AS
Repeat Failure Of Hot
Doug - Vision Video Labs, Inc
Power Supply Screams And Hot Shorts 2hrs After Reb
Can you Help with these Standard Televisions problems?
RCA F25432 25" TV
rca...
Red light is on the television... Answer This...
RCA F25432 25" TV
RCA Model #F25432
Is my TV a digital or analog? Answer This...
RCA F25432 25" TV
RCA F27442 guide plus
during any broadcast tv show,... Answer This...
RCA F25432 25" TV
RCA 27" TV Guide Plus
We unplugged our 27" RCA... Answer This...
RCA F25432 25" TV
How to connect home theatre to...
Hi I have this old RCA tv model... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
