Question about Singer 1120 Mechanical Sewing Machine
Can't reassemble the shuttle/hook in Singer sewing machine - it is Model # 1120 - an inexpensive machine but works great. It jammed and I released the retaining clamps (?) and the other little parts fell out and now I don't know who to put it back together. I cannot find the manual. Thanks
  • 25 Answers
Turn the hand wheel until the hook race is in the left position..replace the hook to right side...replace the hook race cover..smooth end to the bottom..and snap back the hook retaining arms...now ready for inserting bobbin case...Good Luck
Posted on Jun 02, 2009
How do I time a bobbin hook on a 153W Singer
all sewing machines are basically the same, the hook that rotates to pick the cotton up off the needle must just enter behind the needle when it's on it's way back up which then grabs the cotton to form the stitch, so you must remove the sole plate to expose the shuttle case remove the shuttle and put to one side, now rotate the hand wheel on the sewing machine in the correct rotation and watch the hook rotate round until it goes behind the needle, just as the needle is starting back up from it's lowest position the hook should just be going behind the needle to pick up the cotton, if this is not the case then loosen the screws that clamp the hook assembly to the shaft and rotate the hook assembly gently until the hook is just going behind the needle and make sure the hook is close to the needle before retightening the clamping crews , and final give it a few turns by hand to make sure the hook locates the same all the time and the hook is not catching the needle, when your happy, then reassemble.
Happy sewing
Feb 16, 2015 | Singer Sewing Machines
How do I reassemble shuttle hook on euro pro sewing machine
Typically, they go together like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
May 08, 2014 | Euro-Pro Sewing Machines
Needle stops part way down and won't go any further
Sounds like a bad jam. Clean the machine (you may need to take the needle plate off as well as take the bobbin case and shuttle apart) and put in a new needle and try again.
Jan 17, 2014 | Singer 1120 Mechanical Sewing Machine
How do you work a 1120 singer sewing machine
singer has a free pdf manual to download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 1120) & click search
May 27, 2012 | Singer 1120 Mechanical Sewing Machine
Both hook retaining arms for the hook race cover have broken and I can't find replacement parts.
check with these site--you may have to email some of them about the part
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
ebay
May 19, 2012 | Singer 1120 Mechanical Sewing Machine
Brother 1120 sewing machine timing adjustment
Easy to do remove sole plate remove shuttle and case, don't forget to pull the spring loaded plate to one side by inserting a electrical screw driver in the slot and twisting it anticlockwise to release the case, remove drive dogs this will the expose the cotton pickup assembly turn the hand wheel anticlockwise until the hook gets close to the needle now watch the needle it should be in the lowest position and just as it starts it's way back up the hook should be just going behind the needle to pick up the tread if this is not the case and it's out of position then hold the hand wheel tight and insert a small screw driver into one of the gaps in the base were the shuttle case fits in away that you are able to move the hook assembly one way or the other with a gentle pressure and move the hook just to make it enter just behind the needle as it only just starts it's way up at this position it is now complete and you can reassemble and run slowly at first just to make sure things are okay.
Happy Sewing
Oct 15, 2011 | Singer 1120 Mechanical Sewing Machine
Unable to reassemble bobbin case and shuttle on 1120 Singer Do you have a diagram or other help?
The great thing about Singer is they have almost any manual you'll need even for ancient machines online. Downloads are free.
http://www.singerco.com/accessories/manuals.html
Have a super day!
Mar 13, 2011 | Singer 1120 Mechanical Sewing Machine
The singer 1120 keeps jamming on me what do i do
Thread is caught in the shuttle area, remove your bobbin and brush out area, if that does not help call Singer customer service, at www.singerco.com
Aug 23, 2010 | Singer 1120 Mechanical Sewing Machine
Singer sewing machine jammed after sewing over straight pin
The shuttle and needle timing needs to be re-set. Also the hook needs to be inspected for damage.
Oct 14, 2009 | Singer Sewing Machines
Singer 1120 Mechanical Sewing Machine Logo
710 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
