Question about Dryers
Dryer takes a least two cycles to dry a load and just started making a strange noise.
  • 38 Answers
Hi,if you belt runs blower and tumbler,it could be lose belt,or worn out. the blower creates draft in dryer,and tumbler to fluff up. if the speed of tumbler or blower is not rite it will take long time to dry.and the nosie is the belt sliping.
Posted on May 31, 2009
Dryer not drying completely
More of the lint and mouse junk may have moved up closer to the dryer wall. Take the dryer hvent hose off the dryer to see if there is more stuff in it. Sound like the tub cannot move.
Nov 15, 2012 | LG DLE2514 Electric Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
The start button is flashing red and beeping and the drying cycle won't start. Help!
  • If the machine shakes or makes a lot of noise, make sure the dryer is level. Some shaking is normal, but it shouldn't bounce around like it's itching to go somewhere. Adjust the leveling legs. They just screw and unscrew. Check to make sure the load inside the dryer is properly distributed and is not all clumped together.
  • Match the control settings to the type of load, and make sure you're not overloading the dryer.
  • Check that the ducts aren't blocked if the clothes take too long to dry. Look for lint or missing socks. Check to make sure the ducting isn't kinked, and make sure the outside dryer vent flap moves freely and isn't blocked---by snow, for example.
  • Sort your clothes by weight if they aren't drying properly. Lightweight clothes should be dried separately from items like comforters.
  • Make sure the lint drawer is empty.
  • Press the "Stop" button or press the "Lock" button for three seconds if the controls don't work. Press the "Power" button to wake the dryer up if it won't start. Make sure the "Delay Start" button isn't flashing if the machine fails to start. Press "Start" again.
  • If you see only lights displayed on the screen and no numbers, it's normal. The dryer has detected a low level of moisture. Other normal behavior is when the time remaining jumps to a lower number---it's revising its estimated time remaining. When you can't make a selection and the dryer beeps twice, the dryness setting is incompatible with the chosen dry cycle hope this helps please tell me if it does
Dec 06, 2010 | Zanussi Dryers
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Makes noise while turning with nothing in it
Disconnect vent from back and do a load. If it dries in a cycle then you have a bad venting system. May need to be taken apart and oiled up with some turbine oil.
Aug 12, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer runs for a little then stops, runs, stops now won't start at all. I played with the dryer outlet switch it started again but now stopped.
It might just be getting too hot, are you drying too big of a load? could also be bearings going out, does it make a strange noise when you try to start it?
Jun 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Dryers Logo
109 people viewed this question
Top Dryers Experts
