Question about Canon PIXMA MP830 All-In-One InkJet Printer
My MP830 printer won't print.
"service error 5100" appears on the LCD screen.
  • 489 Answers
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Posted on May 29, 2009
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
Jan 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
On printer screen it is showing Error 6A00 and error code. Whats does this mean and how can I fix it
In my IP 3000 during a print suddenly on the 3rd page, a big "crunch" sound. Paper was jammed - error 5100 or smthg, and managed to remove the paper... but then error 6A00 came up. I found this post and was saved. Manually moved the print head left and right, turned the printer on/off. Still the same error. Then I noticed a piece of torn paper lodged inside. Removed that, got inky fingers, and finally got printer in working condition.
Try to clean any foreign object inside.May be it can help you.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Mar 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
